I have a Lenovo V15 laptop where I have "obligatory system 11", separate NTFS partition and Ubuntu Studio. NTFS partition was created by Linux and was done to share data between both systems. All was working quite smoothly (like half year) until few days ago I cannot mount this partition:
An error occurred while accessing '131,8 GiB Internal Drive (nvme0n1p6)', the system responded: The requested operation has failed: Error mounting /dev/nvme0n1p6 at /media/xxxxx : wrong fs type, bad option, bad superblock on /dev/nvme0n1p6, missing codepage or helper program, or other error.
and seems to be corrupted:
$ sudo ntfsfix /dev/nvme0n1p3
Mounting volume... NTFS signature is missing.
FAILED
Attempting to correct errors... NTFS signature is missing.
FAILED
Failed to startup volume: Invalid argument
Trying the alternate boot sector
Unrecoverable error
Volume is corrupt. You should run chkdsk.
but from "only right system" everything is perfect, no errors, tested with recommended software. I always shutdown "this system" if I have to use it, I also remove/turn off all hibernation/ hybrid shutdown (whatever they call it). it does not help. The partition is invisible for Linux. Is there any solution for it?
