Upgrade proceeds till it throws this error
W:G-P-G error: https://dl.winehq.org/wine-builds/ubuntu focal In-release: The following signatures couldn't be verified because the public key is not available:
then lists about 50 faults mostly like W:Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:
then fails and closes
Any way to push through this?
later Edit - By making sure I updated all programs beforehand, not just security updates (which was what I had updates set to) I reduced it down to 1 error instead of 50; but the same fail to upgrade.
Try the following:
Open a terminal.
Run in it:
sudo apt update
sudo apt install --reinstall synaptic
sudo synaptic
In Synaptic, click on : ---> settings ---> repositories
Disable, by unchecking the box, the one that gives you problems (https://dl.winehq.org/wine-builds/ubuntu focal) and all those that are not original from Ubuntu, ppa, opera, google, etc. etc.
Close Synaptic
Run:
sudo apt update
sudo apt dist-upgrade
sudo apt autoremove
sudo apt clean
Close the terminal.
Start the upgrade process
kyodake
  • 17,808
