15
Whenever I issue command sudo apt-get install ** it does not ask for password, not in my admin user too.
How to make it prompt for password?
My sudoer :
ubuntu:~$ sudo cat /etc/sudoers
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults    env_reset
Defaults    secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
ALL ALL=(ALL) NOPASSWD:ALL
shantanu
  • 8,835
data9
  • 243
Edit /etc/sudoers using sudo visudo, and remove the last line:
(By the way, please note that this line at the end of the file is not the preferred way to make sudo not prompt for a password, for those who want to do that.)
Eliah Kagan
  • 119,640
Use this command to find the source of the problem:
sudo grep -HRn NOPASSWD /etc/sudoers.d/
In my case:
/etc/sudoers.d/50_stack_sh:1:username ALL=(root) NOPASSWD:ALL
comment the line with # and close your terminal.
d a i s y
  • 5,551
hamza
  • 71
I think it is better to add the "admin user" at the end of the file, because the admin should not have to put the password in every order in the terminal, and no other user is allowed to do it neither:
Defaults    env_reset
# ALL ALL=(ALL) NOPASSWD:ALL
(user here) ALL=(ALL) NOPASSWD:ALL
Panther
  • 104,528
