I am new to ubuntu. I have follow the step in Wine, but stuck here... May I know any solution? (regardless stable,staging or devel, all return same error)
$ sudo apt install --install-recommends winehq-devel
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: winehq-devel : Depends: wine-devel (= 10.0.0~noble-1) E: Unable to correct problems, you have held broken packages.
add the below to sources.list and solved
deb http://archive.ubuntu.com/ubuntu noble main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu noble-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu noble-security main restricted universe multiverse
