I have a dual boot system with Ubuntu Desktop and Ubuntu Server. GRUB menu says Ubuntu (which is the desktop version) ubuntu 24.04.1 LTS (on /dev/sdb2) (which os the server version)
I would like GRUB to say:
  • ubuntu 24.04.1 LTS Desktop
  • ubuntu 24.04.1 LTS Server
Is there any simple way to achive this.
Regards Bernhard
You can achieve this by editing the Grub config file:
  1. Boot into your Ubuntu Desktop and open the Grub configuration file:
     sudo nano /etc/default/grub
  2. Comment the line starting with GRUB_DISTRIBUTOR and add one line:
    # GRUB_DISTRIBUTOR=`( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null || echo Ubuntu`
    GRUB_DISTRIBUTOR="ubuntu 24.04.1 LTS Desktop"
  3. Save the file and run the following command:
    sudo update-grub
It will be reflected on the Grub menu on reboot. Do the same to your Ubuntu server OS.
Ajay
  • 2,241
You can use grub customizer tool on ubuntu desktop its a handy tool to edit boot entries or add themes on the flashscreen
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt install grub-customizer
Search for the application grub customizer.
Source: https://itsfoss.com/install-grub-customizer-ubuntu/
