I get the following error after updating Ubuntu using the command sudo do-release-upgrade
Error: Sparse file not allowed
452: out of range pointer: "0x100010"
I ran the Boot-Repair info summary and these are the results. How can I fix this error?
============================== Boot Info Summary ===============================
=> Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of the same hard drive for core.img. core.img is at this location and looks for (,msdos7)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
=> Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of the same hard drive for core.img. core.img is at this location and looks for (hd0,msdos1)/boot/grub. It also embeds following components:
modules
biosdisk fshelp fat exfat ext2 ntfs ntfscomp part_msdos
sda1: __________________________________________________________________________
File system:       ntfs
Boot sector type:  NTFS
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:
sda2: __________________________________________________________________________
File system:       ntfs
Operating System:  Windows 8 or 10
Boot files:
sda3: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sda4: __________________________________________________________________________
File system:       Extended Partition
Boot sector type:  -
Boot sector info:
sda5: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sda6: __________________________________________________________________________
File system:       vfat
Boot sector type:  Grub2 (v1.99-2.00)
Boot sector info:  Grub2 (v2.00) is installed in the boot sector of sda6
                   and looks at sector 852045824 of the same hard drive
                   components:
                   modules
                   -------------------------. No errors found in the Boot
                   Parameter Block.
Operating System:
Boot files:
sda7: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 24.04.1 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
                   /boot/grub/i386-pc/core.img
sdb1: __________________________________________________________________________
File system:       vfat
Boot sector type:  MSWIN4.1: FAT32
Operating System:
Boot files:        /boot/grub/grub.cfg /efi/boot/bootx64.efi
                   /efi/boot/grubx64.efi /efi/boot/mmx64.efi
================================ 2 OS detected =================================
OS#1 (linux): Ubuntu 24.04.1 LTS on sda7 OS#2 (windows): Windows 8 or 10 on sda2
================================ Host/Hardware =================================
CPU architecture: 64-bit Video: Skylake GT2 [HD Graphics 520] from Intel Corporation Live-session OS is Ubuntu 64-bit (Ubuntu 24.04.1 LTS, noble, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: 1.13.0(1.13) from Dell Inc. The firmware is EFI-compatible, and is set in EFI-mode for this live-session. SecureBoot disabled (confirmed by mokutil). BootCurrent: 0007 Timeout: 0 seconds BootOrder: 0003,0001,0004,0005,0007,0009 Boot0000* ubuntu HD(4,MBR,0x53863aa0,0x3238bffe,0x7ef4002)/HD(2,MBR,0x0,0x3238c000,0x8e800)/File(\EFI\ubuntu\shimx64.efi) Boot0001* Diskette Drive BBS(Floppy,Diskette Drive,0x0)0000424f Boot0002* Ubuntu HD(4,MBR,0x53863aa0,0x3238bffe,0x7ef4002)/HD(2,MBR,0x0,0x3238c000,0x8e800)/File(\EFI\ubuntu\shimx64.efi) Boot0003* USB Storage Device BBS(USB,SanDisk,0x0)0000424f Boot0004* CD/DVD/CD-RW Drive BBS(CDROM,CD/DVD/CD-RW Drive,0x0)0000424f Boot0005* Internal HDD BBS(HD,Internal HDD,0x0)0000424f Boot0007* UEFI: SanDisk, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(0,0)/HD(1,MBR,0x38b5d406,0x800,0x3a7f7e0)0000424f Boot0009* UEFI: Samsung SSD 850 EVO M.2 500GB, Partition 4 HD(4,MBR,0x53863aa0,0x3238bffe,0x7ef4002)/File(EFI\boot\bootx64.efi)0000424f
39bc76ff6662f4fbe9aa116e4c997b41 sda6/BOOT/fbx64.efi 4ba5a5aad43c197e9fb58b76b404d287 sda6/BOOT/mmx64.efi df697393036a90b6a84d524ce39ec945 sda6/ubuntu/grubx64.efi 4ba5a5aad43c197e9fb58b76b404d287 sda6/ubuntu/mmx64.efi 07e25dcaf57c776875f78fa36827c58e sda6/ubuntu/shimx64.efi 07e25dcaf57c776875f78fa36827c58e sda6/BOOT/BOOTX64.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda : notGPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, has-win, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda2 : is-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, end-after-100GB sda3 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, end-after-100GB sda6 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, grubenv-ok, noupdategrub, end-after-100GB sda7 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, end-after-100GB
Partitions info (2/3): _________________________________________________________
sda1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, bootmgr, is-winboot, ntfs sda2 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, bootmgr, is-winboot, ntfs sda3 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ntfs sda6 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, vfat sda7 : isnotESP, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ext4
Partitions info (3/3): _________________________________________________________
sda1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda2 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda3 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda6 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda7 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, customized, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors Disk identifier: 0x53863aa0 Boot Start End Sectors Size Id Type sda1 * 2048 104447 102400 50M 7 HPFS/NTFS/exFAT sda2 104448 842578404 842473957 401.7G 7 HPFS/NTFS/exFAT sda3 975699968 976769023 1069056 522M 27 Hidden NTFS WinRE sda4 842579966 975699967 133120002 63.5G 5 Extended sda5 965627904 975699967 10072064 4.8G 82 Linux swap / Solaris sda6 * 842579968 843163647 583680 285M ef EFI (FAT-12/16/32) sda7 843165696 965619711 122454016 58.4G 83 Linux Partition table entries are not in disk order. Disk sdb: 29.25 GiB, 31406948352 bytes, 61341696 sectors Disk identifier: 0x38b5d406 Boot Start End Sectors Size Id Type sdb1 * 2048 61341663 61339616 29.2G c W95 FAT32 (LBA)
parted -lm (filtered): _________________________________________________________
sda:500GB:scsi:512:512:msdos:ATA Samsung SSD 850:; 1:1049kB:53.5MB:52.4MB:ntfs::boot; 2:53.5MB:431GB:431GB:ntfs::; 4:431GB:500GB:68.2GB:::; 6:431GB:432GB:299MB:fat32::boot, esp; 7:432GB:494GB:62.7GB:ext4::; 5:494GB:500GB:5157MB:linux-swap(v1)::swap; 3:500GB:500GB:547MB:ntfs::msftres; sdb:31.4GB:scsi:512:512:msdos:SanDisk Cruzer Blade:; 1:1049kB:31.4GB:31.4GB:fat32::boot, lba;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
├─sda1 ntfs C2B62CF2B62CE89D 53863aa0-01 System Reserved ├─sda2 ntfs F8242E08242DCB08 53863aa0-02
├─sda3 ntfs 9C3EF92D3EF90156 53863aa0-03
├─sda4 53863aa0-04
├─sda5 swap f4cf9b24-9734-424c-9378-d0faca1917b9 53863aa0-05
├─sda6 vfat 0D27-67E6 53863aa0-06
└─sda7 ext4 ce8ce987-6942-40b3-821f-bafff4278f76 53863aa0-07
sdb
└─sdb1 vfat 3482-B7A6 38b5d406-01 UBUNTU 24_0
Mount points (filtered): _______________________________________________________
                    Avail Use% Mounted on
/dev/sda1 23.5M 53% /mnt/boot-sav/sda1 /dev/sda2 92.7G 77% /mnt/boot-sav/sda2 /dev/sda3 50.5M 90% /mnt/boot-sav/sda3 /dev/sda6 272.3M 4% /mnt/boot/efi /dev/sda7 9.9G 78% /mnt /dev/sdb1 23.4G 20% /cdrom efivarfs 125.6K 66% /sys/firmware/efi/efivars
Mount options (filtered): ______________________________________________________
/dev/sda1 fuseblk ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096 /dev/sda2 fuseblk ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096 /dev/sda3 fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 /dev/sda6 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro /dev/sda7 ext4 rw,relatime /dev/sdb1 vfat ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
====================== sda7/boot/grub/grub.cfg (filtered) ======================
Ubuntu ce8ce987-6942-40b3-821f-bafff4278f76
END /etc/grub.d/30_os-prober_proxy
UEFI Firmware Settings uefi-firmware
END /etc/grub.d/30_uefi-firmware
========================== sda7/etc/fstab (filtered) ===========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda7 during installation
UUID=ce8ce987-6942-40b3-821f-bafff4278f76 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda6 during installation
swap was on /dev/sda5 during installation
UUID=f4cf9b24-9734-424c-9378-d0faca1917b9 none swap sw 0 0
======================= sda7/etc/default/grub (filtered) =======================
GRUB_DEFAULT="0" GRUB_TIMEOUT_STYLE="menu" GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR="lsb_release -i -s 2&gt; /dev/null || echo Debian" GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX="" GRUB_DISABLE_OS_PROBER=false
==================== sda7: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
414.597663879 = 445.170851840 boot/grub/grub.cfg 1 406.287132263 = 436.247486464 boot/grub/i386-pc/core.img 1 446.527339935 = 479.455080448 boot/vmlinuz 7 459.413883209 = 493.291900928 boot/vmlinuz-6.8.0-45-generic 7 446.527339935 = 479.455080448 boot/vmlinuz-6.8.0-51-generic 7 459.413883209 = 493.291900928 boot/vmlinuz.old 7 433.161861420 = 465.104007168 boot/initrd.img 86 454.122478485 = 487.610298368 boot/initrd.img-6.8.0-45-generic 78 433.161861420 = 465.104007168 boot/initrd.img-6.8.0-51-generic 86 454.122478485 = 487.610298368 boot/initrd.img.old 78
===================== sda7: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18133 Sep 11 13:15 10_linux -rwxr-xr-x 1 root root 43202 Sep 11 13:15 10_linux_zfs -rwxr-xr-x 1 root root 14513 Sep 11 13:15 20_linux_xen -rwxr-xr-x 1 root root 786 Sep 11 13:15 25_bli -rwxr-xr-x 1 root root 13120 Sep 11 13:15 30_os-prober.dpkg-dist -rwxr-xr-x 1 root root 250 Mar 10 2024 30_os-prober_proxy -rwxr-xr-x 1 root root 1174 Sep 11 13:15 30_uefi-firmware -rwxr-xr-x 1 root root 722 Dec 5 15:53 35_fwupd -rwxr-xr-x 1 root root 214 Dec 18 2022 40_custom -rwxr-xr-x 1 root root 215 Dec 18 2022 41_custom drwxr-xr-x 4 root root 4096 Mar 10 2024 backup drwxr-xr-x 2 root root 4096 Mar 10 2024 bin drwxr-xr-x 2 root root 4096 Mar 10 2024 proxifiedScripts
====================== sdb1/boot/grub/grub.cfg (filtered) ======================
Try or Install Ubuntu Ubuntu (safe graphics) Boot from next volume UEFI Firmware Settings Test memory
==================== sdb1: Location of files loaded by Grub ====================
        ?? = ??             boot/grub/grub.cfg                             1
mount -t ntfs-3g -o remove_hiberfile /dev/sda2 /mnt/boot-sav/sda2
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would purge (in order to remove grub-efi) and reinstall the grub2 of sda7 into the MBR of sda. Grub-efi would not be selected by default because legacy Windows detected. Additional repair would be performed: unhide-bootmenu-10s
Confirmation request before suggested repair: __________________________________
LegacyWindows detected. The boot of your PC is in EFI mode. You may want to retry after changing it to BIOS-compatibility/CSM/Legacy mode. Are you sure you want to continue anyway?
Final advice in case of suggested repair: ______________________________________
The boot files of [sda7 (end>100GB)] are far from the start of the disk. Your BIOS may not detect them. You may want to retry after creating a /boot partition (EXT4, >200MB, start of the disk). This can be performed via tools such as gParted. Then select this partition via the [Separate /boot partition:] option of [Boot Repair]. (https://help.ubuntu.com/community/BootPartition)Please set your BIOS in Legacy mode in order to start your Ubuntu 24.04.1 LTS, then type command [sudo update-grub] in order to add the Windows entry to your GRUB menu.
karel
  • 122,292
  • 133
  • 301
  • 332
