After upgrading from Ubuntu 20.04 to Ubuntu 24.04, installing applications no longer works. When installing via snap from e.g. Chromium, I get the following error:
root@pc123456:/home/name# snap install chromium-browser
snap: error while loading shared libraries: libX11.so.6: cannot open shared object file: No such file or directory
I have now spent the whole morning searching through various forum entries, some of them very old, that point to this error, but unfortunately I cannot find a working solution.
Among other things, I have already tried:
  • Reinstalling libx11-6 and
  • Reinstalling snapd
All were to no avail. Now I don't know what to do next.
Unable to connect Snap Store:
karel
  • 122,292
  • 133
  • 301
  • 332
taenzer1978
I don't know if you have icaclient installed (Citrix) but it turned out that was the culprit on my machine. I had recently updated it and it prompts about an "app protection" component.
On other sites people are talking about LD_PRELOAD etc causing this sort of thing, but env|grep LD only showed OLDPWD so I at first thought that wasn't the issue. But using ldd on /usr/bin/snap showed /usr/local/lib/AppProtection/libAppProtection.so and /usr/local/lib looked sus and searches about it mention Citrix. It turns out that "app protection" injects something into preload via some sort of systemd mechanism.
To fix it I ran apt remove --purge icaclient and then reinstalled icaclient (deb from Citrix website) and made sure that app protection was disabled during reinstall. Afterwards I also ran sudo service snapd restart to get snap running, but reboot would work.
Had the same happen when icaclient was installed (Citrix).
Anyway, removing the icaclient and its dependencies, and restarting snapd resolved the problem.
They even have it documented:
https://docs.citrix.com/en-us/citrix-workspace-app/app-protection.html#:~:text=App%20Protection%20is%20not%20supported%20when%20you%20launch,use%20snap%20applications%20when%20App%20Protection%20is%20installed.
In Citrix Workspace app for Linux, you're unable to use snap applications when App Protection is installed.
I can confirm - The icaclient was the culprit. My client was from the Citrix web site.
sudo dpkg --purge icaclient
Did the trick, no reboot required.
Thanks @ib-mmsys for pointing me to icaclient as the cause.
