I have an Ubuntu box "k3" attached to a physical network 192.168.86.0/24 and a tplink deco router on 192.168.86.1. k3's IP is 192.168.86.53.
On the ubuntu box, I created a ipvlan l3 network:
podman network create -d ipvlan --subnet 192.168.3.0/24 --opt mode=l3 ipvlan
A container is deployed on 192.168.3.3. The following communication are successful:
- podman host to container
- another host to container (after adding static route for 192.168.3.0/24)
- container to host network
But the container cannot talk to the Internet. Tried pinging 1.1.1.1 & 8.8.8.8 and there was no response. A static route for 192.168.3.0/24 is already added to my deco router. Packet capture on the host network shows there are no reply.
root@k3:~# tcpdump -nn -v icmp -i enp1s0 -c3
tcpdump: listening on enp1s0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
14:42:16.851045 IP (tos 0x0, ttl 64, id 36288, offset 0, flags [DF], proto ICMP (1), length 84)
192.168.3.3 > 1.1.1.1: ICMP echo request, id 10, seq 130, length 64
14:42:17.851604 IP (tos 0x0, ttl 64, id 36463, offset 0, flags [DF], proto ICMP (1), length 84)
192.168.3.3 > 1.1.1.1: ICMP echo request, id 10, seq 131, length 64
14:42:18.852261 IP (tos 0x0, ttl 64, id 36506, offset 0, flags [DF], proto ICMP (1), length 84)
192.168.3.3 > 1.1.1.1: ICMP echo request, id 10, seq 132, length 64
3 packets captured
3 packets received by filter
0 packets dropped by kernel
I also tried setting up NAT on the podman host. net.ipv4.ip_forward is turned on and the FORWARD chain allows all traffic.
iptables -t nat -A POSTROUTING -s 192.168.3.0/24 -j MASQUERADE
Packet capture now showed the reply, but they did not actually make it into the container.
14:46:27.439541 IP (tos 0x0, ttl 64, id 2763, offset 0, flags [DF], proto ICMP (1), length 84)
192.168.86.53 > 1.1.1.1: ICMP echo request, id 16, seq 0, length 64
14:46:27.442535 IP (tos 0x2c, ttl 55, id 17039, offset 0, flags [none], proto ICMP (1), length 84)
1.1.1.1 > 192.168.86.53: ICMP echo reply, id 16, seq 0, length 64
14:46:27.442642 IP (tos 0x2c, ttl 54, id 17039, offset 0, flags [none], proto ICMP (1), length 84)
1.1.1.1 > 192.168.3.3: ICMP echo reply, id 16, seq 0, length 64
3 packets captured
Ping output from my alpine container:
/ # ping 1.1.1.1 -c1
PING 1.1.1.1 (1.1.1.1): 56 data bytes
--- 1.1.1.1 ping statistics ---
1 packets transmitted, 0 packets received, 100% packet loss
I think my deco router doesn't want to route addresses outside of the LAN range. But setting NAT on the podman host should work? What am I missing? I want my containers to be able to connect to the Internet.
