I'm trying to upgrade from Bionic 18.04.6 LTS, but I am running into problems. I've looked at
EOL Upgrade Ubuntu 18.04.6 LTS (Bionic Beaver)
https://help.ubuntu.com/community/FocalUpgrades
Uprading Ubuntu 18.04.6 LTS to 20.04
Here's what I get.
$ sudo do-release-upgrade -c
Checking for a new Ubuntu release
New release '20.04.6 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
Please install all available updates for your release before upgrading.
This is interesting because the Kubuntu Software Center (Discover) says my system is up to date.
$ sudo apt update
Hit:2 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:1 https://packages.microsoft.com/repos/code stable InRelease
Get:6 https://download.docker.com/linux/ubuntu bionic InRelease [64.4 kB]
Hit:7 https://esm.ubuntu.com/apps/ubuntu bionic-apps-security InRelease
Hit:8 https://esm.ubuntu.com/apps/ubuntu bionic-apps-updates InRelease
Hit:9 https://esm.ubuntu.com/infra/ubuntu bionic-infra-security InRelease
Hit:10 https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates InRelease
Fetched 64.4 kB in 2s (42.4 kB/s)
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
No updates are reported. Next I try the full upgrade.
$ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Next I try update-manager. A window says
The software on this computer is up to date.
However, Kubuntu 20.04.6 LTS is now available (you have 18.04).
I click to upgrade, and it says
apt-mark showhold shows no held packages.
At this point, I'm stumped, and it seems like I'm going in circles. Can anyone help?
UPDATE
Thank you, @guiverc. I didn't look at the upgradable package because I thought I should only consider updates, not upgrades. Here's the output:
$ apt list --upgradable
Listing... Done
code/stable 1.96.2-1734607745 amd64 [upgradable from: 1.83.1-1696982868]
N: There are 129 additional versions. Please use the '-a' switch to see them.
I tried to upgrade the package identified, but I got an error that I don't really understand.
$ sudo apt upgrade code/stable
Selected version '1.96.2-1734607745' (code stable:stable [amd64]) for 'code'
code : Depends: libc6 (>= 2.28) but 2.27-3ubuntu1.6+esm3 is to be installed
Depends: libxkbfile1 (>= 1:1.1.0) but 1:1.0.9-2 is to be installed
E: Broken packages
@karel - I'm sorry, I don't see how the page you suggested applies. I'm drawing from the ESM sources, so I don't see how changing to old-releases would help. Please clarify if I'm missing something.
@guiverc - I checked the sources in update-manager and both Canonical-supported (main) and Community-maintained (universe) boxes are checked.
SUCCESS!
@guiverc - Thank you so much! That is indeed the problem. I did
$ sudo apt remove code/stable
Then the upgrade worked!
