When I booted my system today, I got the following error messages:
Jan 07 19:38:25 ubuntu20 systemd[1]: Condition check resulted in System Security Services Daemon being skipped.
Jan 07 19:38:25 ubuntu20 systemd[1]: Reached target User and Group Name Lookups.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-nss.socket: Bound to unit sssd.service, but unit isn't active.
Jan 07 19:38:25 ubuntu20 systemd[1]: Dependency failed for SSSD NSS Service responder socket.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-nss.socket: Job sssd-nss.socket/start failed with result 'dependency'.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-autofs.socket: Bound to unit sssd.service, but unit isn't active.
Jan 07 19:38:25 ubuntu20 systemd[1]: Dependency failed for SSSD AutoFS Service responder socket.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-autofs.socket: Job sssd-autofs.socket/start failed with result 'dependency'.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-pac.socket: Bound to unit sssd.service, but unit isn't active.
Jan 07 19:38:25 ubuntu20 systemd[1]: Dependency failed for SSSD PAC Service responder socket.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-pac.socket: Job sssd-pac.socket/start failed with result 'dependency'.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-pam-priv.socket: Bound to unit sssd.service, but unit isn't active.
Jan 07 19:38:25 ubuntu20 systemd[1]: Dependency failed for SSSD PAM Service responder private socket.
Jan 07 19:38:25 ubuntu20 systemd[1]: Dependency failed for SSSD PAM Service responder socket.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-pam.socket: Job sssd-pam.socket/start failed with result 'dependency'.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-pam-priv.socket: Job sssd-pam-priv.socket/start failed with result 'dependency'.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-ssh.socket: Bound to unit sssd.service, but unit isn't active.
Jan 07 19:38:25 ubuntu20 systemd[1]: Dependency failed for SSSD SSH Service responder socket.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-ssh.socket: Job sssd-ssh.socket/start failed with result 'dependency'.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-sudo.socket: Bound to unit sssd.service, but unit isn't active.
Jan 07 19:38:25 ubuntu20 systemd[1]: Dependency failed for SSSD Sudo Service responder socket.
Jan 07 19:38:25 ubuntu20 systemd[1]: sssd-sudo.socket: Job sssd-sudo.socket/start failed with result 'dependency'.
Jan 07 19:38:25 ubuntu20 systemd[1]: Starting Accounts Service...
It seems because of this sudo has also stopped working. I'm now getting sudo: 3 incorrect password attempts. Everything was fine yesterday, I have not made any changes to my system or installed any software.
Update:
~$ systemctl status sssd
○ sssd.service - System Security Services Daemon
Loaded: loaded (/lib/systemd/system/sssd.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Condition: start condition failed at Tue 2025-01-07 19:38:24 EST; 30min ago
├─ ConditionPathExists=|/etc/sssd/sssd.conf was not met
└─ ConditionDirectoryNotEmpty=|/etc/sssd/conf.d was not met
~$ systemctl start sssd
Which prompted me, "Authentication Required", My password was accepted.
Condition: start condition failed at Tue 2025-01-07 20:12:37 EST; 15min ago
Jan 07 20:12:37 ubuntu20 systemd[1]: Condition check resulted in System Security Services Daemon being skipped.
Now sudo is working. Why does SSSD interfere with sudo functionality?
~$ journalctl -xeu sssd.service
Support: http://www.ubuntu.com/support
A start job for unit sssd.service has finished successfully.
The job identifier is 199.
-- Boot 12bc6c7bf6f14ab8a277022b764c4482 --
Jan 07 19:27:30 ubuntu20 systemd[1]: Condition check resulted in System Security Services Daemon being skipped.
Subject: A start job for unit sssd.service has finished successfully
Defined-By: systemd
The job identifier is 183.
-- Boot 002196eb090942a8bf85fb57d3466b96 --
Defined-By: systemd
The job identifier is 103.
Defined-By: systemd
