Ive just did a fresh install of "Ubuntu 24.10" downloaded from the official site.
The problem is that my wifi adapter is not being recognized - not even in "additional drivers".
The network adapter is: BCM43142 802.11b/g/n
Ive tried solution #3 from this site:
https://itsfoss.com/fix-no-wireless-network-ubuntu/
or specificaly sudo apt install firmware-b43-installer but it didnt helped.
The wifi was working fine in 24.04 and the "secure boot" is disabled.
Can someone help me with this issue?
Thanks in advance... :)
stumblebee
  • 4,379
Merlo
I can confirm that doing a fresh install of "Ubuntu 24.04" downloaded from the official site, then the wifi is working since the beginning. Upgrade from 24.04 to 24.10 has solved the issue - wifi stayed operational. Thanks to everyone for their help.
Merlo
First, make sure you don't turned off the wifi by the keyboard button
Connect to the internet by cable or mobile USB cable and apply these commands:
wget http://www.lwfinger.com/b43-firmware/broadcom-wl-6.30.163.46.tar.bz2
tar xfvj broadcom-wl-6.30.163.46.tar.bz2
sudo apt install b43-fwcutter
sudo b43-fwcutter -w /lib/firmware broadcom-wl-6.30.163.46/broadcom-wl-6.30.163.46.wl_apsta.o
sudo modprobe -r b43 bcma
sudo modprobe -r brcmsmac bcma
sudo modprobe -r wl
sudo modprobe b43
if you see this error after the last command "FATAL: Module b43 not found in directory /lib/modules/6.8.0-31-generic", do these:
sudo apt install linux-firmware linux-modules-6.8.0-31-generic linux-modules-extra-6.8.0-31-generic
sudo modprobe b43
make sure to replace 6.8.0-31 with appropriate numbers based on your kernel
Installing Broadcom Wireless Drivers
Talaat Etman
  • 1,340
