For quite some time I encounter an error with tex-common whenever I try to free disk-space by running the command sudo apt-get autoremove. The error is as follows:
dpkg: error processing package tex-common (--configure):
installed tex-common package post-installation script subprocess returned error exit status 2
tex-common
I tried sudo dpkg -C and sudo dpkg --configure tex-common as well as sudo apt-get install --reinstall tex-common with similar output.
I also tried to reconfigure the locale-setting (as recommended in this post Failing to configure tex-common on Ubuntu 20.04.2 LTS ) but that didn't fix the problem. I get the following warning in a addition:
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = "en_US.UTF-8",
LC_TIME = "de_AT.UTF-8",
LC_MONETARY = "de_AT.UTF-8",
LC_ADDRESS = "de_AT.UTF-8",
LC_TELEPHONE = "de_AT.UTF-8",
LC_NAME = "de_AT.UTF-8",
LC_MEASUREMENT = "de_AT.UTF-8",
LC_IDENTIFICATION = "de_AT.UTF-8",
LC_NUMERIC = "de_AT.UTF-8",
LC_PAPER = "de_AT.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
I guess that the error I encounter has something to do with the texlive-installation. I currently use texlive 2023 which is located in /usr/local/texlive. However, tex-common is in /usr/share/tex-common. I upgraded to texlive 2023 about 1,5 years ago and in the beginning everything worked smoothly (as far as I remember).
I don't know how to fix the problem and don't want to make anything worse (than I have maybe done already). Hence, I kindly ask for help from the community. Please let me know if additional output or information is needed.
