I am having issues with LDAP. I have an overarching VM openbsd that has the LDAP database that all other VM's access based on certificating. SO far, it has been conveniently set up so that all I have to do is scp a cacert.pem file into the file, configure whatever ldap.conf file is in the destination VM after installing the necessary utilities, and I should be connected to the database and be able to use the ldap accounts from my VM effortlessly. However whenever I try and use the VM to id placeholder that should simply work from nssconfig, something like id username of ldap account does not work. Whenever I look into the authentification logs, they just say:
ubuntu sudo: nss_ldap: reconnecting to LDAP server... ubuntu sudo: nss_ldap: failed to bind to LDAP server ldaps://servername: Protocol error
I have done all the tests to make sure everything else works, and they do.
openssl s_client -connect This test worked and I was able to connect
ldapsearch -x -b "dc=placeholder,dc=placeholder" "(uid=placeholder)"
The above also worked, so I know my LDAP root account works, that I can connect to the LDAP database, and that the account I am trying to id exists, so the issue has to be in ubuntu, but I don't know how to fix it.
The only thing I can think of is off the nsswitch.conf, which I didn't change much just:
passwd:         files systemd ldap
group:          files systemd ldap
shadow:         files systemd ldap
gshadow:        files systemd
hosts: files dns networks: files
protocols: db files services: db files ethers: db files rpc: db files
netgroup: nis
