I have just bought a new Lenovo Ideapad slim 5i laptop, 1tb ssd. I've just installed linux but when handling with partition there was a 900tb nfts partition and i used part of it to install linux. Right now Ubuntu works but I don't manage to use windows. On the grub menu if I select windows I see automatical repair but then it fails to repair. Anyone could help me to restore windows? Right now on the disk utility app I have the following situation:
- 273 MB — 218 MB free (20.0% full), FAT (32-bit version) — Mounted at /boot/efi, /dev/nvme0n1p1, EFI System
- 273 MB, /dev/nvme0n1p2, Microsoft Reserved
- 350 GB — 316 GB free (9.7% full), Ext4 (version 1.0) — Mounted at Filesystem Root, /dev/nvme0n1p3, Linux Filesystem -672 GB, Unallocated Space, /dev/nvme0n1 -2.1 GB, NTFS — Not Mounted, /dev/nvme0n1p4, Microsoft Windows Recovery Environment (System, No Automount)
Before installing Linux the 350GB and 672 partitions were only one NFTS partition.
I would be very grateful if you can help me!!
After the testdisk analysis I got the following result:
Disk /dev/nvme0n1 - 1024 GB / 953 GiB - CHS 976762 64 32
Partition Start End Size in sectors
P EFI System 2048 534527 532480 [EFI System Partition]
P Linux filesys. data 567296 684163071 683595776
D MS Data 684163072 1996312575 1312149504 [Windows]
D MS Data 1992216577 1996312576 4096000
>D MS Data 1996312576 2000408575 4096000 [WINRE_DRV]
Then proceeding on MS Data [WINRE_DRV] with deepsearch I obtain the following result:
>D EFI System 2048 534527 532480 [EFI System Partition] [SYSTEM_DRV]
D MS Data 2054 534533 532480 [SYSTEM_DRV]
D MS Data 72763 78936 6174
D MS Data 78936 85109 6174 [Boot]
