Recently I've installed Ubuntu 24.04.1 LTS and I've connected my external HDD and it was detected but today something happened and it didn't recognize it at all. I've tried turning off the computer and reconnecting it again but it didn't work. Tried to connect it to another computer and it works so the problem isn't with the hdd but something with the os(ubuntu) but I can't seem to figure out what exactly. Can somebody help me?
Tried sudo fdisk -l
Disk /dev/sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: TOSHIBA THNSNK25
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 61D1FEFA-18BA-424D-8696-F3076A4D4D30
Device Start End Sectors Size Type /dev/sda1 2048 4095 2048 1M BIOS boot /dev/sda2 4096 500115455 500111360 238.5G Linux filesystem
When I run this command sudo inxi -F it shows me only my internal SSD:
Drives:
  Local Storage: total: 238.47 GiB used: 58.84 GiB (24.7%)
  ID-1: /dev/sda vendor: Toshiba model: THNSNK256GCS8 SATA 256GB
Partition:
  ID-1: / size: 233.67 GiB used: 58.84 GiB (25.2%) fs: ext4 dev: /dev/sda2
