I installed pgadmin4 on my ubuntu with sudo apt-get pgadmin4. Apparently this makes the pgadmin binary end up in a directory that is not in PATH for some reason, namely in /usr/pgadmin4/bin. Therefore I added it to PATH in my .bashrc:
export PATH="$PATH:/usr/pgadmin4/bin"
Now when I restart my terminal I can invoke pgadmin4 from the cli with just pgadmin4 and it will find the binary.
But when I try to run the application from i3's executor dmenu (mod+d by default), pgadmin4 doesn't show up in the suggestions. I assume this is because i3 is not aware of the altered PATH configuration that I did in .bashrc. How can I make i3 aware of it?
glades
  • 187
Don't put PATH definitions in .bashrc. They don't belong there, and this is also why your i3 isn't seeing it, most likely, since .bashrc is only read by interactive shells.
So if you add the same line:
To ~/.profile that should most likely work.
terdon
  • 104,119
