I was trying to sudo apt-get upgrade
the sub-step of upgrading boot-repair is breaking my process.
I focused on upgrading boot-repair only. here is my attempt:
root@poppy:/etc/apt/sources.list.d# cat /etc/issue
Ubuntu 22.04.5 LTS \n \l
root@poppy:/etc/apt/sources.list.d# cat yannubuntu-ubuntu-boot-repair-jammy.list
deb https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu/ jammy main
deb-src https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu/ jammy main
root@poppy:/etc/apt/sources.list.d# apt-get update
Hit:1 http://us.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:5 https://ppa.launchpadcontent.net/x2go/stable/ubuntu jammy InRelease
Hit:6 https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu jammy InRelease
Reading package lists... Done
root@poppy:/etc/apt/sources.list.d# apt-get install -y boot-repair
Building dependency tree... Done
The following additional packages will be installed:
boot-sav
Suggested packages:
boot-info dmraid lvm2 mdadm os-uninstaller zfsutils-linux
The following packages will be upgraded:
boot-repair boot-sav
2 upgraded, 0 newly installed, 0 to remove and 13 not upgraded.
Need to get 538 kB of archives.
After this operation, 3,072 B of additional disk space will be used.
Ign:1 https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu jammy/main amd64 boot-sav all 4ppa2079
Ign:2 https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu jammy/main amd64 boot-repair all 4ppa2079
Err:1 https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu jammy/main amd64 boot-sav all 4ppa2079
404 Not Found [IP: 185.125.190.80 443]
Err:2 https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu jammy/main amd64 boot-repair all 4ppa2079
E: Failed to fetch https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu/pool/main/b/boot-repair/boot-sav_4ppa2079_all.deb 404 Not Found [IP: 185.125.190.80 443]
E: Failed to fetch https://ppa.launchpadcontent.net/yannubuntu/boot-repair/ubuntu/pool/main/b/boot-repair/boot-repair_4ppa2079_all.deb 404 Not Found [IP: 185.125.190.80 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@poppy:/etc/apt/sources.list.d# ping ppa.launchpadcontent.net
PING ppa.launchpadcontent.net (185.125.190.80) 56(84) bytes of data.
64 bytes from ppa.launchpadcontent.net (185.125.190.80): icmp_seq=1 ttl=54 time=136 ms
64 bytes from ppa.launchpadcontent.net (185.125.190.80): icmp_seq=2 ttl=54 time=137 ms
^C
--- ppa.launchpadcontent.net ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 136.401/136.482/136.563/0.081 ms
