I have a 22.04 server running PM2 on it to provide some node applications. These applications rely on a shell variable that says if the environment is 'dev' or 'prd'
Every time I reboot the system I have to run
export ENV_TYPE = 'dev'
and then restart all the PM2 processes with
pm2 restart 0 --update-env
pm2 restart 1 --update-env
and so on
How can I build a script that will perform these actions automatically when I reboot the server (not after login, right at the end of boot procedures)? Later on I will look into run the script but now the goal is to create the script
  • vi ~/$USER/script.sh Replace script,sh to something more descriptive.
  • press i
  • paste this:
      #!/bin/bash
  • press and type <ESC>:wq! and then
  • chmod 750 ~/$USER/script.sh
and you have a script. Move it to a directory in echo $PATH if you need direct access to it.
The next step is to add it to /etc/crontab with @reboot as time or (the better but a bit more difficult method) to create a systemd service so you can add it somewhere in the boot chain and have a start/stop/restart feature,
Rinzwind
  • 309,379
