I remember using a Ubuntu Linux utility to interpret (in English) the following:
SG_IO: bad/missing sense data, sb[]:  f0 00 05 04 71 40 01 0a 00 00 00 00 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
But I forgot the name of the utility. So I do not know what SG_IO is complaining about. The closest reference I could find on this forum's website was: Hard Drive error: bad/missing sense data; but that reference has a different sense data error, so the cause of the error is most likely different on that site. And similarly from the site hdparm error: SG_IO: bad/missing sense data
I am trying to secure-erase the drive using the first parameter:
hdparm --user-master u --security-set-pass p /dev/sda
That is what is the source of the error code. Of course that needs to work properly to be able to secure-erase the disk using:
hdparm --user-master u --security-erase p /dev/sda
I tried downloading sdparm but I did not find anything equivalent in its help package to perform a secure erase.
It seems that this disk might be fine. But without secure erase, I am not sure. I do not want others exposed to old data on the disk, as I want to perform a completely new install.
  1. What is the Uubntu utility to get an English explanation from the sense date of the problem with hdparm?
  2. With the given issue from HDParm, is there a way to setup secure erase differently, or what can be done?
I appreciate the community's support. Thank you in advance.
Update: The disk was bad.
I wrote zeros to the disk using the dd command:
root@stephen-All-Series:~# sudo dd if=/dev/zero of=/dev/sda bs=64K count=100000 status=progress
6104678400 bytes (6.1 GB, 5.7 GiB) copied, 13 s, 470 MB/s
100000+0 records in
100000+0 records out
6553600000 bytes (6.6 GB, 6.1 GiB) copied, 14.3532 s, 457 MB/s
Then I checked if the zeros were written to the disk using:
dd if=/dev/sda bs=64K count=10000 status=progress
A whole bunch of text spewed out indicating that the zeros were not properly written to the SSD disk. The disk is bad is the problem. However, I am still interested in knowing what the utility is that interprets the sense data to English, that I used before, but that I forgot what it is.
Thank you everyone for your support!
