-1
Using Ubuntu 11.04.. Updated gimp 2.6 to gimp 2.7. But have problem in installig gimp-plugin-registry
rajesh@rajesh-System-Product-Name:~$ sudo apt-get install gimp-plugin-registry -y
[sudo] password for rajesh:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 gimp-plugin-registry : Depends: gimp (<= 2.7) but 2.7.3-2011052002~nn is to be installed
E: Broken packages
Mitch
  • 109,787
Rajesh
I suggest you to upgrade to Gimp 2.8
GIMP 2.8 stable installation
If you're upgrading from an older GIMP version please visit the link and pay attention to the 'dist-upgrade' command http://www.webupd8.org/2012/05/gimp-28-stable-finally-available-for.html (also if you want to revert to GIMP 2.6.x)
If you're just installing GIMP for the first time on your current system install:
sudo add-apt-repository ppa:otto-kesselgulasch/gimp
sudo apt-get update
GIMP Plugin Registry for GIMP 2.8 installation
sudo apt-get update
penreturns
  • 5,950
