Possible Duplicate:
Can't boot without Flash Drive plugged in
I installed Ubuntu 12.04 LTS in my Dell Inspiron 1545 from a usb stick but it is not booting up when I removed the usb from the computer. but it is working when I put the usb in my computer. I want ubuntu to start without the usb. Please can you help me? Thanks.
Sounds like grub has been installed to the usb. From your booted Ubuntu system, open a terminal, then use the following commands to install grub to the internal drive :
sudo grub-install /dev/sdX
sudo update-grub
Replacing sdX with the actual drive, which will probably be sda, but use disk utility to double check if you are unsure.
Accidently installed grub to usb
