I've just installed Ubuntu 12.04 and was about to manually install Rawstudio with the packages from SourceForge repo, but I've been stuck with dependency issues and I am short on apt command lines to sort this out.
Here's the report I'v got :
    installArchives() failed: dpkg: dependency problems prevent configuration of     libgphoto2-2:
     libgphoto2-2 depends on libjpeg62; however:
     Package libjpeg62 is not installed.
     libgphoto2-l10n (2.4.13-1ubuntu1) breaks libgphoto2-2 (<= 2.4.10.1-4) and is installed.
      Version of libgphoto2-2 to be configured is 2.4.10.1-0ubuntu3~maverick.
      dpkg: error processing libgphoto2-2 (--configure):
      dependency problems - leaving unconfigured
    No apport report written because MaxReports is reached already
    dpkg: dependency problems prevent configuration of libgphoto2-2-dev:
    libgphoto2-2-dev depends on libgphoto2-2 (= 2.4.10.1-0ubuntu3~maverick); however:
      Package libgphoto2-2 is not configured yet.
    dpkg: error processing libgphoto2-2-dev (--configure):
     libgphoto2-2
     libgphoto2-2-dev
    Error in function:
    SystemError: E:Sub-process /usr/bin/dpkg returned an error code (1)
I've tried "apt-get -f install" but without success. What is the mahick command line that will unblock the situation ?
Thanks
Seb
You can use the rawstudio's ppa:
sudo apt-add-repository ppa:rawstudio/ppa
sudo apt-get update
sudo apt-get purge --remove rawstudio
sudo apt-get install rawstudio-daily
After that you can run it with rawstudio-daily command.
Note that the version from this ppa is the same like that what you can find at http://rawstudio.org/files/daily/
Seth
  • 59,332
Frantique
  • 8,673
