Possible Duplicate:
Boot failure : No DEFAULT or UI configuration directive found!
Salam everyone. I searched the entire forum but no solution worked for me. I downloaded the ISO image of Ubuntu 12.4. and by using Unetbootin I made my USB drive bootable.
But on booting it gives error "syslinux 3.86 2010-04-01 ebios copyright 1994-2010 H. Peter Anvin et al. no default or UI configuration diretive found. boot:"
I checked the md5sum they are also fine. I tried changing folder and file names to sys and formated my derive fat32 and fat but nothing worked. I tried different boot programs like LiLo and linuxpenderive.
But Mr. Peter Anvin is not willing to leave my boot screen. so what should I do??
Thanks in advance
Aleikum Salam!
I give you 2 solutions:
  1. Format the stick as FAT16 (or just FAT), not as FAT32.
  2. Type: mboot.c32 -c boot.cfg at the boot: prompt.
Frantique
  • 8,673
After eliminating MBR of a USB drive by the following command , and try reformatting in fat32 form (and add boot flag) by Gparted.
sudo dd if=/dev/zero of=/dev/sdx bs=512 count=1
Caution: /dev/sdx should replace to the device name of USB drive.
vine_user
  • 2,871
