I've seen someone do this: open multiple terminal sessions. Go in ssh inside different machines. Select group broadcast functionality. give the same command to every ssh session, eventually remove broadcast, give commands to a single terminal and then broadcast again. Can the ubuntu gnome terminal do that? what terminal should I install to get that functionality?
            Asked
            Active
            Viewed 95 times
            I've been told that it is Terminator, you use ctrl shift o or ctrl shift e and then select group and then brodcast group.
        Malkavian
- 225
