So, I recently got a Lenovo Ideapad Slim 3 that came with Windows 11. I decided to make it dual boot with Ubuntu 24.04. Install seemed to work ok, but when the grub window appears and I select Ubuntu, I get this:
BusyBox v1.36.1 (Ubuntu 1:1.36.1-6ubuntu3.1) built-in shell (ash)
(initramfs)
I type 'exit' and get this:
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
--Check rootdelay= (did the system wait long enough?)
-Missing modules (cat /proc/modules: ls /dev)
ALERT! UUID=e5d4b1c7-b00a-41bc-8903-e9693c289d1c does not exist
I gather somehow the system cannot find a crucial partition, but I cannot find how to fix it. Upon searching some people seem to have similar problems, but no solutions have worked as yet.
Things tried:
- Reinstalling Ubuntu
- Turned off secure boot in UEFI. Returned the possibility to run memtest from grub boot.
- David's suggestion from UUID=xxx does not exist. Dropping to a shell on standard (no dual boot) on Lenovo Idea Pad 3
- Listing the partitions at grub command line shows everything fine as far as I can see.
- Running boot-repair twice. "Successful" both times. Last report here: https://paste.ubuntu.com/p/2FJt3HV56f
I would drop the dual boot and just run Ubuntu, but I have a suspicion I'd face the same issue. If you need more info just ask and I'll provide.
