I'm trying to install libpango1.0-dev (in order to then install librealsense2-utils). When I run apt-cache policy libpango1.0-dev, I get:
libpango1.0-dev:
  Installed: (none)
  Candidate: 1.50.6+ds-2
  Version table:
     1.50.6+ds-2 500
        500 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
Indicating that the package is available from the official Ubuntu repositories.
When I then run sudo apt install libpango1.0-dev, I get this:
The following packages have unmet dependencies: libpango1.0-dev : Depends: gir1.2-pango-1.0 (= 1.50.6+ds-2) but 1.50.6+ds-2ubuntu1 is to be installed Depends: libpango-1.0-0 (= 1.50.6+ds-2) but 1.50.6+ds-2ubuntu1 is to be installed Depends: libpangocairo-1.0-0 (= 1.50.6+ds-2) but 1.50.6+ds-2ubuntu1 is to be installed Depends: libpangoft2-1.0-0 (= 1.50.6+ds-2) but 1.50.6+ds-2ubuntu1 is to be installed Depends: libpangoxft-1.0-0 (= 1.50.6+ds-2) but 1.50.6+ds-2ubuntu1 is to be installed Depends: pango1.0-tools (= 1.50.6+ds-2) E: Unable to correct problems, you have held broken packages.
If I read this correctly, the version of libpango1.0-dev that I am trying to install depends on the "generic" versions of several libraries, but the only versions available for my system are Ubuntu-specific versions.
Am I interpreting this correctly? If so, doesn't that make this version incompatible with my system? Why would this version of libpango1.0-dev be available from the official Ubuntu repo?
A coworker of mine with the same issue decided to try to replace those 6 packages with the required versions. The result was a thoroughly broken system and a reinstall of the OS.
Details:
  • OS is Ubuntu 22.04.4 LTS
  • No packages are held
  • I ran apt update and apt upgrade before doing anything. Both completed without errors.
