First of all, I'm using Ubuntu 24.10 in a live USB environment.
I'm not a complete novice in linux, but i'm not well-versed either.
My issue is that I cannot make the bluetooth work in Linux, the on/off toggle moves but BT stays off, but it works pretty much out of the box in Windows 11 (I'm using 2 different boot drives). The Wifi/BT chip is a MediaTek MT7925, integrated on the motherboard (Gigabyte X870 Eagle WIFI7).
The wifi works correctly out of the box, although I do not care much as I use a wired ethernet connection, but I am trying to connect an XBox Elite controller through bluetooth, and the first step for it is having a working bluetooth connection.
There seems to be an error in dmesg about BT:
$ sudo dmesg | grep Bluetooth
[ 13.033377] Bluetooth: Core ver 2.22
[ 13.033393] Bluetooth: HCI device and connection manager initialized
[ 13.033395] Bluetooth: HCI socket layer initialized
[ 13.033396] Bluetooth: L2CAP socket layer initialized
[ 13.033399] Bluetooth: SCO socket layer initialized
[ 13.100488] Bluetooth: hci0: Opcode 0x0c03 failed: -16
[ 13.179806] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.179809] Bluetooth: BNEP filters: protocol multicast
[ 13.179811] Bluetooth: BNEP socket layer initialized
I tried using bluetoothctl to power it on, but it says that it couldn't find a default adapter:
$ bluetoothctl
Agent registered
[bluetooth]# power on
No default controller available
[bluetooth]# exit
As far as my google-fu could find, this chip is not that recent, and my kernel should have drivers for it. lsusb doesn't show any MediaTek equipment, and hcitool dev returns nothing either:
$ hcitool dev
Devices:
Here's hciconfig -a
$ hciconfig -a
hci0: Type: Primary Bus: USB
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN
RX bytes:6 acl:0 sco:0 events:1 errors:0
TX bytes:0 acl:0 sco:0 commands:1 errors:1
Features: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Packet type: DM1 DH1 HV1
Link policy:
Link mode: PERIPHERAL ACCEPT
I'm not knowledgeable enough to know what else to do from here unfortunately, any help would be very welcome!
