I am trying to upgrade Ubuntu.
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
sudo do-release-upgrade
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading.
There is one package remaining which needs to be updated:
r-base-dev/bionic-cran40 4.4.2-1.1804.0 all [upgradable from: 4.3.0-1.1804.0]
N: There are 28 additional versions. Please use the '-a' switch to see them.
sudo apt install r-base-dev=4.4.2-1.1804.0
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: r-base-dev : Depends: libdeflate-dev but it is not installable E: Unable to correct problems, you have held broken packages.
I try to install libdeflate-dev, but not possible:
sudo apt install libdeflate-dev
Package libdeflate-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libdeflate-dev' has no installation candidate
Also trying to use the software updater by pressing 'upgrade'is not helping since it does nothing then.
I would be very thankful for ideas and help!
Marcel
You need to install Ubuntu Pro @ https://ubuntu.com/pro/ . This will allow you to update 18.04 and then after you install ALL updates you can upgrade to 20.04 and it's free. I will say that I have a dual-boot with 18.04 and 20.04 and 18.04 is better. It uses less CPU and memory and does NOT have Tracker-Miner. Tracker-Miner is baked-into 20.04 and is a resource pig. It uses mass CPU and memory which causes temperature increases and fan RPM to sky-rocket. At any rate, that's the fix. 18.04 is awesome ! Just sayin'.
