I have a dual boot setup with Windows 11 and Ubuntu 24.04.
When I've been using my Bluetooth headphones (Sony wf-700cn) on Ubuntu and boot to Windows, I can reconnect fairly easily. Windows gives me a notification to configure the device, which then leads to a prompt asking whether I trust the device.
When connecting to my Android devices, all I need to do is go through the Bluetooth menu and tap on the device to reconnect.
When I want to connect my headphones on Ubuntu, going through Bluetooth settings to connect flashes the message "Connecting" and then goes back to "Disconnected". I need to remove the device, put the headphones into pairing mode, and then connect.
Is it possible to get do whatever it is that Windows and/or my Android devices do, so I can skip the pairing mode?
I've found this question that talks about a reverse problem, and this question where re-pairing does not solve the issue. Blueman does not work, it tells me br-connection-canceled, nor does manually trusting or setting the Name = Bluez in /etc/bluetooth/main.conf.
