I recently installed Fedora and Ubuntu 12.04. Both have different Swap Partition. Fedora using its own Swap space. But Ubuntu using both two swap partitions. I want to stop that. I want Ubuntu 12 to use its own Swap Partition.
  • sda9 - Ubuntu (/)
  • sda11 - Swap (4.9 GB)
  • sda10 - Fedora (/)
  • sda12 - Swap (4.9 GB)
All are logical partitions.
Hashken
  • 6,340
I suggest that you get rid of the extra swap line in /etc/fstab.
Eliah Kagan
  • 119,640
mdpc
  • 1,219
Please add the noauto option in /etc/fstab for your Ubuntu system's sda10 partition.
Eliah Kagan
  • 119,640
karolszk
  • 603
The swap space is set in /etc/fstab. In your case you probably want Ubuntu to use sda11 partition, so you should remove the line in fstab that contains the /dev/sda12 partition.
Eliah Kagan
  • 119,640
BakaKuna
  • 188
