I installed Ubuntu 24.04.1 LTS several days ago from jammy and my software update app keeps jamming. I've run the commands
sudo apt update; sudo apt upgrade; sudo apt -fix --broken; sudo dpkg --configure -a
and lots of variations. apt policy python3 is returning that I have 3.12.3 ubuntu installed, but the commands above are returning that numerous python programs are not installing and it seems to have something to do with dpkg. I've tried the solutions at Dependency errors for python3 and many others when I run sudo apt-get upgrade to no effect.
In the time since I first made this post, my python-based programs have started working again, specifically gqrx and gnuradio, but when i run sudo apt update and sudo apt upgrade I still get a long return telling me that many python programs are not updated and I still get the dpkg error messages below. The Software Updater app opens and seems to work, but the Software & Updates app does not work.
$ sudo apt update && sudo apt upgrade
[sudo] password for
Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu noble InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu noble-updates InRelease
Hit:4 http://archive.ubuntu.com/ubuntu noble InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu noble-backports InRelease
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
freeglut3 gir1.2-javascriptcoregtk-4.0 gir1.2-soup-2.4 gir1.2-webkit2-4.0
libboost-regex1.74.0 libcupsfilters1 libflac8 libfontembed1 libgcab-1.0-0
libicu70 libjavascriptcoregtk-4.0-18 libldap-2.5-0 libmessaging-menu0
libmpdec3 libnautilus-extension1a libncurses-dev libnfs13 libosmocore18
libosmogb12 libosmogsm17 libpcre3 libplist3 libpoppler118 libpython3.10
libpython3.10-minimal libpython3.10-stdlib libqpdf28 libraw20 libsmbios-c2
libsoup-gnome-2.4-1 libtiff5 libvpx7 libwebkit2gtk-4.0-37
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
693 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up python3 (3.12.3-0ubuntu2) ...
running python rtupdate hooks for python3.12...
/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/library.py:212: SyntaxWarn
ing: invalid escape sequence '\-'
RE_KEY = re.compile('^([a-zA-Z_][a-zA-Z0-9_.\-]*)(\[([a-zA-Z_@]+)\])?$')
/usr/lib/x86_64-linux-gnu/gedit/plugins/snippets/substitutionparser.py:162: Synt
axWarning: invalid escape sequence '\s'
match = re.match('\\\\?%s\s*' % self.REG_GROUP, tokens)
Traceback (most recent call last):
File "/usr/bin/py3clean", line 210, in <module>
main()
File "/usr/bin/py3clean", line 196, in main
pfiles = set(dpf.from_package(options.package))
File "/usr/share/python3/debpython/files.py", line 55, in from_package
raise Exception("cannot get content of %s" % package_name)
Exception: cannot get content of gobject-introspection
error running python rtupdate hook gobject-introspection
/usr/share/hplip/base/imagesize.py:186: SyntaxWarning: invalid escape sequence '
re.compile('\#define\s+\S+\s+\d+') : ('image/x-xbitmap', xbmsize),
/usr/share/hplip/base/imagesize.py:187: SyntaxWarning: invalid escape sequence '
re.compile('\/\* XPM \*\/') : ('image/x-xpixmap', xpmsize),
/usr/share/hplip/base/imagesize.py:189: SyntaxWarning: invalid escape sequence '
re.compile('^II\*\x00') : ('image/tiff', tiffsize),
/usr/share/hplip/fax/ledmfax.py:46: SyntaxWarning: invalid escape sequence '\d'
http_result_pat = re.compile(b"""HTTP/\d.\d\s(\d+)""", re.I)
main()
Exception: cannot get content of libglib2.0-dev-bin
error running python rtupdate hook libglib2.0-dev-bin
/usr/lib/rhythmbox/plugins/alternative-toolbar/alttoolbar_plugins.py:171: Syntax
Warning: invalid escape sequence '\('
translation = re.sub('\(..\)', '', translation, flags=re.DOTALL)
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/AstrawebParser.py:64: SyntaxW
arning: invalid escape sequence '\/'
url = re.split('(\/display[^"]*)', entry)[1]
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/AstrawebParser.py:66: SyntaxW
title = re.split('(\/display[^>]*)([^<]*)', entry)[2][1:].strip()
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/AstrawebParser.py:97: SyntaxW
lyrics = re.split('(<font face=arial size=2>)(.*)(<\/font><br></td><td*)', res
ult)[2]
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/JetlyricsParser.py:50: Syntax
Warning: invalid escape sequence '\.'
m = re.search('<a href=\'(http://jetlyrics\.com/viewlyrics\.php\?id=[0-9]*)\'>
', result)
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/JlyricParser.py:49: SyntaxWar
m = re.search('<div class=\'title\'><a href=\'(/artist/[^\.]*\.html)\'>', resu
lt)
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/TerraParser.py:39: SyntaxWarn
ing: invalid escape sequence '\w'
pattern = re.compile("&(#?\w+?);")
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/WinampcnParser.py:87: SyntaxW
arning: invalid escape sequence '\['
lrcplaintext = re.sub('\[.*?\]', '', lrcplaintext)
/usr/lib/x86_64-linux-gnu/rhythmbox/plugins/lyrics/lyrics.py:44: SyntaxWarning:
LYRIC_TITLE_STRIP=["\(live[^\)]*\)", "\(acoustic[^\)]*\)", "\([^\)]*mix\)", "\
([^\)]*version\)", "\([^\)]*edit\)", "\(feat[^\)]*\)"]
dpkg: error processing package python3 (--configure):
installed python3 package post-installation script subprocess returned error ex
it status 4
dpkg: dependency problems prevent configuration of python3-contextlib2:
python3-contextlib2 depends on python3:any; however:
Package python3 is not configured yet.
dpkg: error processing package python3-contextlib2 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of sssd-common:
sssd-common depends on python3; however:
dpkg: error processing package sssd-common (--configure):
dpkg: dependency problems prevent configuration of sssd-proxy:
sssd-proxy depends on sssd-common (= 2.9.4-1.1ubuntu6.1); however:
Package sssd-common is not configured yet.
dpkg: error processing package sssd-proxy (--configure):
dpkg: dependency problems prevent configuration of python3-opengl:
python3-opengl depends on python3:any; however:
Package python3 is not cNo apport report written because the error message ind
icates its a followup error from a previous failure.
ause the error message indicates its a followup error from a previous failure. [This section repeats.]
dpkg: error processing package python3-opengl (--configure):
dpkg: dependency problems prevent configuration of python3-freetype:
python3-freetype depends on python3:any; however:
dpkg: error processing package python3-freetype (--configure):
dpkg: dependency problems prevent configuration of python3-distupgrade:
python3-distupgrade depends on python3:any; however:
dpkg: error processing package python3-distupgrade (--configure):
dpkg: dependency problems prevent configuration of python3-networkx:
python3-networkx depends on python3:any; however:
dpkg: error processing package python3-networkx (--configure):
dpkg:No apport report written because MaxReports is reached already
No apport rep
dependency pro
blems prevent configuration of python3-markupsafe:
python3-markupsafe depends on python3 (<< 3.13); however:
python3-markupsafe depends on python3 (>= 3.12~); however:
python3-markupsafe depends on python3:any; however:
dpkg: error processing package python3-markupsafe (--configure):
dpkg: dependency problems prevent configuration of python3-sss:
python3-sss depends on python3 (<< 3.13); however:
python3-sss depends on python3 (>= 3.12~); however:
python3-sss depends on python3:any; however:
dpkg: error processing package python3-sss (--configure):
dpkg: dependency problems prevent configuration of pythoNo apport report written
n3-thrift:
python3-thrift depends on python3 (<< 3.13); however:
python3-thrift depends on python3 (>= 3.12~); however:
python3-thrift depends on python3:any; however:
dpkg: error processing package python3-thrift (--configure):
dpkg: dependency problems prevent configuration of printer-driver-postscript-hp:
printer-driver-postscript-hp depends on python3:any; however:
dpkg: error processing package printer-driver-postscript-hp (--configure):
dpkg: dependency problems prevent configuration of software-properties-common:
software-properties-common depends on python3; however:
[deleted for space]
dpkg: error processing package software-properties-common (--configure):
dpkg: dependency problems prevent configuration of apport:
apport depends on python3; however:
dpkg: error processing package apport (--configure):
dpkg: dependency problems prevent configuration of python3-tz:
python3-tz depends on python3:any; however:
dpkg: error processing package python3-tz (--configure):
dpkg: dependency problems prevent configuration of python3-fonttools:
[same as earlier, deleted for space]
dpkg: error processing package python3-fonttools (--configure):
dpkg: dependency problems prevent configuration of pyqt5-dev-tools:
pyqt5-dev-tools depends on python3 (>= 3~); however:
pyqt5-dev-tools depends on python3:any; however:
dpkg: error processing package pyqt5-dev-tools (--configure):
dpkg: dependency problems prevent configuration of python3-apport:
python3-apport depends on python3:any; however:
dpkg: error processing package python3-apport (--configure):
dpkg: dependency problems prevent configuration of netplan.io:
netplan.io depends on python3; however:
dpkg: error processing package netplan.io (--configure):
dpkg: dependency problems prevent configuration of python3-fs:
python3-fs depends on python3-tz; however:
[deleted for space]
dpkg: error processing package python3-fs (--configure):
dpkg: dependency problems prevent configuration of grub-common:
grub-common depends on python3; however:
dpkg: error processing package grub-common (--configure):
dpkg: dependency problems prevent configuration of python3-pil:amd64:
python3-pil:amd64 depends on python3 (<< 3.13); however:
[deleted for space]
dpkg: error processing package python3-pil:amd64 (--configure):
dpkg: dependency problems prevent configuration of sssd-ipa:
sssd-ipa depends on sssd-common (= 2.9.4-1.1ubuntu6.1); however:
dpkg: error processing package sssd-ipa (--configure):
dpkg: dependency problems prevent configuration of python3-cups:amd64:
python3-cups:amd64 depends on python3 (<< 3.13); however:
python3-cups:amd64 depends on python3 (>= 3.12~); however:
dpkg: error processing package python3-cups:amd64 (--configure):
dpkg: dependency problems prevent configuration of python3-tdb:
python3-tdb depends on python3 (<< 3.13); however:
[deleted for space]
dpkg: error processing package python3-tdb (--configure):
dpkg: dependency problems prevent configuration of python3-pygments:
python3-pygments depends on python3:any; however:
dpkg: error processing package python3-pygments (--configure):
dpkg: dependency problems prevent configuration of python3-packaging:
[deleted for space]
dpkg: error processing package python3-packaging (--configure):
dpkg: dependency p
roblems prevent configuration of python3-software-properties:
python3-software-properties depends on python3; however:
python3-software-properties depends on python3:any; however:
dpkg: error processing package python3-software-properties (--configure):
dpkg: dependency p
roblems prevent configuration of gnuradio:
gnuradio depends on python3-opengl; however:
Package python3-opengl is not configured yet.
gnuradio depends on python3-packaging; however:
Package python3-packaging is not configured yet.
gnuradio depends on python3-thrift; however:
Package python3-thrift is not configured yet.
gnuradio depends on python3 (<< 3.13); however:
gnuradio depends on python3 (>= 3.12~); however:
gnuradio depends on python3:any; however:
dpkg: error processing package gnuradio (--configure):
dpkg: dependency p
roblems prevent configuration of python3-pil.imagetk:amd64:
python3-pil.imagetk:amd64 depends on python3-pil (= 10.2.0-1ubuntu1); however:
Package python3-pil:amd64 is not configured yet.
python3-pil.imagetk:amd64 depends on python3 (<< 3.13); however:
python3-pil.imagetk:amd64 depends on python3 (>= 3.12~); however:
python3-pil.imagetk:amd64 depends on python3:any; however:
dpkg: error processing package python3-pil.imagetk:amd64 (--configure):
dpkg: dependency p
roblems prevent configuration of bpfcc-tools:
bpfcc-tools depends on python3:any; however:
dpkg: error processing package bpfcc-tools (--configure):
dpkg: dependency p
roblems prevent configuration of python3-jsonschema:
python3-jsonschema depends on python3-importlib-resources | python3-supported-m
in (>> 3.9); however:
Package python3-importlib-resources is not installed.
Package python3-supported-min is not installed.
Package python3 which provides python3-supported-min is not configured yet.
python3-jsonschema depends on python3-typing-extensions | python3-supported-min
(>> 3.8); however:
Package python3-typing-extensions is not installed.
python3-jsonschema depends on python3:any; however:
dpkg: error processing package python3-jsonschema (--configure):
dpkg: dependency p
roblems prevent configuration of sssd-ad-common:
sssd-ad-common depends on sssd-common (= 2.9.4-1.1ubuntu6.1); however:
dpkg: error processing package sssd-ad-common (--configure):
dpkg: dependency p
roblems prevent configuration of python3-pyqt5.qwt:
python3-pyqt5.qwt depends on python3 (<< 3.13); however:
[deleted for space]
dpkg: error processing package python3-pyqt5.qwt (--configure):
dpkg: dependency p
roblems prevent configuration of python3-rlpycairo:
python3-rlpycairo depends on python3-freetype; however:
[deleted for space]
dpkg: error processing package python3-rlpycairo (--configure):
dpkg: dependency p
roblems prevent configuration of sssd-krb5-common:
sssd-krb5-common depends on sssd-common (= 2.9.4-1.1ubuntu6.1); however:
dpkg: error processing package sssd-krb5-common (--configure):
dpkg: dependency p
roblems prevent configuration of python3-zmq:
python3-zmq depends on python3 (<< 3.13); however:
python3-zmq depends on python3 (>= 3.12~); however:
python3-zmq depends on python3:any; however:
dpkg: error processing package python3-zmq (--configure):
dpkg: dependency p
roblems prevent configuration of python3-brotli:
python3-brotli depends on python3 (<< 3.13); however:
python3-brotli depends on python3 (>= 3.12~); however:
[deleted for space]
dpkg: error processing package python3-brotli (--configure):
dpkg: dependency p
roblems prevent configuration of gr-osmosdr:
gr-osmosdr depends on python3 (<< 3.13); however:
gr-osmosdr depends on python3 (>= 3.12~); however:
gr-osmosdr depends on python3:any; however:
dpkg: error processing package gr-osmosdr (--configure):
dpkg: dependency p
roblems prevent configuration of python3-cryptography:
python3-cryptography depends on python3 (>= 3~); however:
[deleted for space]
dpkg: error processing package python3-cryptography (--configure):
dpkg: dependency p
roblems prevent configuration of python3-mdurl:
python3-mdurl depends on python3:any; however:
dpkg: error processing package python3-mdurl (--configure):
dpkg: dependency p
roblems prevent configuration of libvolk-bin:
libvolk-bin depends on python3:any; however:
dpkg: error processing package libvolk-bin (--configure):
dpkg: dependency p
roblems prevent configuration of python3-dev:
python3-dev depends on python3 (= 3.12.3-0ubuntu2); however:
dpkg: error processing package python3-dev (--configure):
dpkg: dependency p
roblems prevent configuration of python3-gi:
python3-gi depends on python3 (<< 3.13); however:
[deleted for space]
dpkg: error processing package python3-gi (--configure):
dpkg: dependency p
roblems prevent configuration of python3-cycler:
python3-cycler depends on python3:any; however:
dpkg: error processing package python3-cycler (--configure):
dpkg: dependency p
roblems prevent configuration of python3-kiwisolver:
python3-kiwisolver depends on python3 (<< 3.13); however:
python3-kiwisolver depends on python3 (>= 3.12~); however:
python3-kiwisolver depends on python3-typing-extensions | python3-supported-min
(>= 3.8); however:
python3-kiwisolver depends on python3:any; however:
dpkg: error processing package python3-kiwisolver (--configure):
dpkg: dependency p
roblems prevent configuration of python3-brlapi:amd64:
python3-brlapi:amd64 depends on python3 (<< 3.13); however:
python3-brlapi:amd64 depends on python3 (>= 3.12~); however:
dpkg: error processing package python3-brlapi:amd64 (--configure):
dpkg: dependency p
roblems prevent configuration of python3-ldb:
python3-ldb depends on python3 (<< 3.13); however:
[deleted for space]
dpkg: error processing package python3-ldb (--configure):
dpkg: dependency p
roblems prevent configuration of python3-markdown:
python3-markdown depends on python3:any; however:
dpkg: error processing package python3-markdown (--configure):
dpkg: dependency p
roblems prevent configuration of python3-ufolib2:
python3-ufolib2 depends on python3-fonttools (>= 4.29.1); however:
Package python3-fonttools is not configured yet.
python3-ufolib2 depends on python3-typing-extensions | python3-supported-min (>
= 3.8); however:
python3-ufolib2 depends on python3:any; however:
dpkg: error processing package python3-ufolib2 (--configure):
dpkg: too many errors, stopping
Errors were encoun
tered while processing:
python3
python3-contextlib2
sssd-common
sssd-proxy
python3-opengl
python3-freetype
python3-distupgrade
python3-networkx
python3-markupsafe
python3-sss
python3-thrift
apport
python3-tz
python3-fonttools
pyqt5-dev-tools
python3-apport
netplan.io
python3-fs
grub-common
python3-pil:amd64
sssd-ipa
python3-cups:amd64
python3-tdb
python3-pygments
python3-packaging
gnuradio
bpfcc-tools
python3-jsonschema
sssd-ad-common
python3-pyqt5.qwt
python3-rlpycairo
sssd-krb5-common
python3-zmq
python3-brotli
gr-osmosdr
python3-mdurl
libvolk-bin
python3-dev
python3-gi
python3-cycler
python3-kiwisolver
python3-ldb
python3-markdown
python3-ufolib2
Processing was halted because there were too many errors.
