Issue :
I accidentally deleted the file ld-linux-x86-64.so.2 -> /lib/x86_64-linux-gnu/ld-linux-x86-64.so.2 ( is in /usr/lib64/ ) on my Linux server, which has now rendered all commands unusable, and I can no longer connect to the server. Since this library file is essential for dynamic linking, almost every command I attempt fails with errors related to missing dependencies.
System Information:
OS: Ubuntu 22.04.5 LTS (Jammy Jellyfish)
File Deleted: ld-linux-x86-64.so.2 -> /lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
What I've Tried:
  • Rebooting the server (same issue persists).
  • Accessing through SSH and local terminal commands, but neither works due to missing dependencies.
My Goal: To restore the ld-linux-x86-64.so.2 -> /lib/x86_64-linux-gnu/ld-linux-x86-64.so.2 file so that the server can run commands again and operate normally.
graham
  • 13,061
rayudu
