twice I got this cache error. I do not recall how I fixed it the first time. Had done search on internet but some solution did not fix it or could not apply to my situation.
It happened 5-10 minutes after I had purged Chrome that I had installed.
Why is it even happening?
Why does the package have a (1) at the end? Is it a duplicate file?
browserice:~$ sudo apt-get update
[sudo] password for browserice:
Hit:1 http://ca.archive.ubuntu.com/ubuntu noble InRelease
Hit:2 http://ca.archive.ubuntu.com/ubuntu noble-updates InRelease
Hit:3 http://ca.archive.ubuntu.com/ubuntu noble-backports InRelease
Hit:4 https://repo.steampowered.com/steam stable InRelease
Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
Reading package lists... Error!
E: Unable to parse package file /var/lib/apt/lists/ca.archive.ubuntu.com_ubuntu_dists_noble-updates_multiverse_binary-amd64_Packages (1)
W: You may want to run apt-get update to correct these problems
E: The package cache file is corrupted
browserice:~$ sudo apt-get clean
browserice:~$ sudo apt-get autoclean Reading package lists... Error! E: Unable to parse package file /var/lib/apt/lists/ca.archive.ubuntu.com_ubuntu_dists_noble-updates_multiverse_binary-amd64_Packages (1) W: You may want to run apt-get update to correct these problems E: The package cache file is corrupted
browserice:~$ sudo apt-get autoremove Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
browserice:~$ sudo cat /etc/apt/sources.list
Ubuntu sources have moved to /etc/apt/sources.list.d/ubuntu.sources
browserice:~$ sudo cat /etc/apt/sources.list.d/ubuntu.sources Types: deb URIs: http://ca.archive.ubuntu.com/ubuntu/ Suites: noble noble-updates noble-backports Components: main restricted universe multiverse Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg
Types: deb URIs: http://security.ubuntu.com/ubuntu/ Suites: noble-security Components: main restricted universe multiverse Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg
browserice:~$ sudo ls -al /var/lib/apt/lists/ca.archive.ubuntu.com_ubuntu_dists_noble-updates_multiverse_binary-amd64_Packages -rw-r--r-- 1 root root 110797 Oct 20 15:48 /var/lib/apt/lists/ca.archive.ubuntu.com_ubuntu_dists_noble-updates_multiverse_binary-amd64_Packages
Found in anothere thread to do the followings:
Try a sudo rm -r /var/lib/apt/lists/* and then run sudo apt-get update again.
The error message is gone.
Now I know what to do when I get this.
But I still did not get an answer why this is happening. I happened twice in 2 weeks !
