The ssh client will check all your keys until it finds one that matches.
This is how it works (this is very simplified, before this a quite complex dance has been made to encrypt all of this):
- The server creates an auth token.
- The token is encrypted using your public key on the server.
- The server send the encrypted token to the client.
- The client tries to decrypt the token, using all known private keys.
- If it is successful it will send the decrypted token back to the server.
- If the token matchs the server will let the client in.
What files are keys depends on the client.
For the Openssh client (Ubuntu default client), according to its man page, the files that are supposed to be private keys are ./sshid_rsa, .ssh/id_dsa, .ssh/id_ecdsa, plus those given after the -i flag (it supports multiple files) and those declared in the config file.
You can give it the -v option to make it print a line when it tries to use any file as a key. This is an example from a non-key login:
$ ssh -v www.hostremoved.com
OpenSSH_5.9p1 Debian-5ubuntu1, OpenSSL 1.0.1 14 Mar 2012
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/javier/.ssh/id_rsa
debug1: Trying private key: /home/javier/.ssh/id_dsa
debug1: Trying private key: /home/javier/.ssh/id_ecdsa
debug1: Next authentication method: password
As you can see, it prints all the keys it tries, it fails all. You can use this in your system to discover what files is ssh using in your own system.
Below you can see the output if some existing key is found and tried
debug1: Offering RSA public key: user@xyz
user@xyz is the information appended to the public key.
If you're wondering how your ssh client finds your private keys, it's not magic. Under Gnome (xfce and KDE also) there is a special ssh-agent that automatically adds keys in .ssh directory that have a correspondending public key with the ending .pub.
If you not have such a comfortable ssh agent, you'll have to add your private keys with ssh-add key.
