I bought a second hand hp pc with about 60 Go on SSD storage and 1 To hard disk. It has windows on the SSD, so I thought I would put Lubuntu on the hard disk.
I got the latest long term support Lubuntu (mangled mantra or whatever - edit : Noble Numbat, 24.04.1) and I checked the hash sum. It was ok. So I rebooted from windows, telling it to boot from usb. It took a long time but eventually it booted and I had the choice between try Lubuntu or install Lubuntu. I chose install.
I selected the hard disk, using the entire hard disk. I didn't know whether grub would add a windows option at boot time, because windows was on the SSD. It never got that far.
The installation seemed to go as usual but at the end it said :
Installation failed
Command <i>calamares-logs-helper /tmp/calamares-root-15j00610</i> finished with exit code 1.
Cannot open '/var/log/casper.log' for reading : input/output error.
and some more stuff about copying calamares files. When I click "ok" it goes back to Lubuntu, as if I had selected "Test Lubuntu".
At first I tried the normal install, then the small install (only Desktop stuff). The third time I thought I should maybe put it online so I did so, via wifi. Same result.
I'm considering trying to create an installation usb stick with the previous LTS Lubuntu, 22.04.5 (Jammy Jellyfish), I can always type "do-release-upgrade" later. But maybe this has nothing to do with it.
It's the first time I try an install on a pc which has both SSD and hard disk. Maybe the problem comes from that?
Now I'm back to windows, which still functions except it can no longer see the hard disk. That is as I expected. I would prefer to keep it for the rare occasions when I might need it, but I'll overwrite it if I have to.
EDIT : The report made by running "boot-repair" with the default options is below.
To bring back windows :
change
/boot/efi/EFI/Microsoft/Boot/rem_bootmgfw.efi
into
/boot/efi/EFI/Microsoft/Boot/bootmgfw.efi
boot-repair-4ppa2081 [20241022_1009]
============================= Boot Repair Summary ==============================
Default settings: ______________________________________________________________
The default repair of the Boot-Repair utility would reinstall the grub-efi of sdb5, using the following options: sdb1/boot/efi Additional repair would be performed: unhide-bootmenu-10s use-standard-efi-file
Final advice in case of suggested repair: ______________________________________
Please do not forget to make your UEFI firmware boot on the The OS now in use - Ubuntu 24.04.1 LTS entry (sdb1/efi/**/grub.efi (** will be updated in the final message) file) ! If your computer reboots directly into Windows, try to change the boot order in your UEFI firmware. If your UEFI firmware does not allow to change the boot order, change the default boot entry of the Windows bootloader. For example you can boot into Windows, then type the following command in an admin command prompt: bcdedit /set {bootmgr} path \EFI**\grub.efi (** will be updated in the final message)
User settings: _________________________________________________________________
modprobe: FATAL: Module efivars not found in directory /lib/modules/6.8.0-47-generic The settings chosen by the user will reinstall the grub-efi of sdb5, using the following options: sdb1/boot/efi Additional repair will be performed: unhide-bootmenu-10s use-standard-efi-file
/boot/efi added in sdb5/fstab /dev/sdb5/boot/efi not empty
Unhide GRUB boot menu in sdb5/etc/default/grub
===================== Reinstall the grub-efi of /dev/sdb5 ======================
grub-install --version grub-install (GRUB) 2.12-1ubuntu7 modprobe: FATAL: Module efivars not found in directory /lib/modules/6.8.0-47-generic modprobe efivars
efibootmgr -v (filtered) before grub install BootCurrent: 0005 Timeout: 20 seconds BootOrder: 0000,3000,0005,2001,2002,2004,0003,0002 Boot0000* Windows Boot Manager HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(EFIMicrosoftBootbootmgfw.efi)RC Boot0001* Windows Boot Manager HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(EFIubuntugrubx64.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000061000100000010000000040000007fff0400 Boot0002* Internal Hard Drive - ST1000LM035-1RK172 BBS(HD,Internal Hard Drive - ST1000LM035-1RK172,0x500)feff05000000000000000000000001062d0052e602000005190052e6410052e6000000020000000000000000000000000000000000000000000000000000000000d887c9ae110002010c00d041030a0000000001010600020801010600000003120a000000000000007fff0400 Boot0003* Internal Hard Drive - SanDisk SD9SN8W-128G-1006 BBS(HD,Internal Hard Drive - SanDisk SD9SN8W-128G-1006,0x500)feff05000000000000000000000001062d0059e602000005190059e6410059e6000000120000000000000000000000000000000000000000000000000000000000088ec9ae120002010c00d041030a0000000001010600020801010600000003120a000100000000007fff0400 Boot0005* ubuntu HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(EFIubuntushimx64.efi) Boot2001* EFI USB Device RC Boot3000* Internal Hard Disk or Solid State Disk RC
uname -r 6.8.0-47-generic
grub-install --efi-directory=/boot/efi --target=x86_64-efi Installing for x86_64-efi platform. Installation finished. No error reported. df /dev/sdb1 mv /boot/efi/EFI/Boot/bootx64.efi /boot/efi/EFI/Boot/bkpbootx64.efi cp /boot/efi/efi/ubuntu/grubx64.efi /boot/efi/EFI/Boot/bootx64.efi
efibootmgr -v (filtered) after grub install BootCurrent: 0005 Timeout: 20 seconds BootOrder: 0005,0000,3000,2001,2002,2004,0003,0002 Boot0000* Windows Boot Manager HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(EFIMicrosoftBootbootmgfw.efi)RC Boot0001* Windows Boot Manager HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(EFIubuntugrubx64.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000061000100000010000000040000007fff0400 Boot0002* Internal Hard Drive - ST1000LM035-1RK172 BBS(HD,Internal Hard Drive - ST1000LM035-1RK172,0x500)feff05000000000000000000000001062d0052e602000005190052e6410052e6000000020000000000000000000000000000000000000000000000000000000000d887c9ae110002010c00d041030a0000000001010600020801010600000003120a000000000000007fff0400 Boot0003* Internal Hard Drive - SanDisk SD9SN8W-128G-1006 BBS(HD,Internal Hard Drive - SanDisk SD9SN8W-128G-1006,0x500)feff05000000000000000000000001062d0059e602000005190059e6410059e6000000120000000000000000000000000000000000000000000000000000000000088ec9ae120002010c00d041030a0000000001010600020801010600000003120a000100000000007fff0400 Boot0005* Ubuntu HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(EFIubuntushimx64.efi) Boot2001* EFI USB Device RC Boot3000* Internal Hard Disk or Solid State Disk RC
update-grub Sourcing file /etc/default/grub' Sourcing file/etc/default/grub.d/lubuntu-grub-theme.cfg' Found theme: /usr/share/grub/themes/lubuntu-grub-theme/theme.txt Found linux image: /boot/vmlinuz-6.8.0-47-generic Found initrd image: /boot/initrd.img-6.8.0-47-generic Found linux image: /boot/vmlinuz-6.8.0-40-generic Found initrd image: /boot/initrd.img-6.8.0-40-generic Found memtest86+ 64bit EFI image: /boot/memtest86+x64.efi Found Ubuntu 22.04.5 LTS (22.04) on /dev/sda1 Found Ubuntu 24.04.1 LTS (24.04) on /dev/sda2 Found Windows Boot Manager on /dev/sdb1@/EFI/Microsoft/Boot/bootmgfw.efi Adding boot menu entry for UEFI Firmware Settings ...
Unhide GRUB boot menu in sdb5/boot/grub/grub.cfg
Boot successfully repaired.
You can now reboot your computer. Please do not forget to make your UEFI firmware boot on the The OS now in use - Ubuntu 24.04.1 LTS entry (sdb1/efi/ubuntu/grubx64.efi file) ! If your computer reboots directly into Windows, try to change the boot order in your UEFI firmware. If your UEFI firmware does not allow to change the boot order, change the default boot entry of the Windows bootloader. For example you can boot into Windows, then type the following command in an admin command prompt: bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
============================ Boot Info After Repair ============================
=> No boot loader is installed in the MBR of /dev/sda. => No boot loader is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 22.04.5 LTS
Boot files:        /etc/fstab /etc/default/grub
sda2: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 24.04.1 LTS
sdb1: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /efi/Boot/bkpbootx64.efi /efi/Boot/bootx64.efi
                   /efi/Boot/fbx64.efi /efi/Boot/mmx64.efi
                   /efi/ubuntu/grubx64.efi /efi/ubuntu/mmx64.efi
                   /efi/ubuntu/shimx64.efi /efi/ubuntu/grub.cfg
                   /efi/Microsoft/Boot/bootmgfw.efi
                   /efi/Microsoft/Boot/bootmgr.efi
                   /efi/Microsoft/Boot/SecureBootRecovery.efi
sdb2: __________________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
sdb3: __________________________________________________________________________
File system:       ntfs
Boot sector type:  NTFS
Operating System:  Windows 10 or 11
Boot files:        /Windows/System32/winload.exe
sdb4: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sdb5: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
================================ 4 OS detected =================================
OS#1 (linux): The OS now in use - Ubuntu 24.04.1 LTS on sdb5 OS#2 (linux): Ubuntu 22.04.5 LTS on sda1 OS#3 (linux): Ubuntu 24.04.1 LTS on sda2 OS#4 (windows): Windows 10 or 11 on sdb3
================================ Host/Hardware =================================
CPU architecture: 64-bit Video: Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] from Advanced Micro Devices, Inc. [AMD/ATI] BOOT_IMAGE of the installed session in use: /boot/vmlinuz-6.8.0-47-generic root=UUID=e473ae63-8a11-4c2d-bd34-b23b26bc9c0a ro quiet splash vt.handoff=7 df -Th / : /dev/sdb5 ext4 59G 8.7G 47G 16% /
===================================== UEFI =====================================
BIOS/UEFI firmware: F.13(15.13) from Insyde The firmware is EFI-compatible, and is set in EFI-mode for this installed-session. SecureBoot disabled (confirmed by mokutil). BootCurrent: 0005 Timeout: 20 seconds BootOrder: 0005,0000,3000,2001,2002,2004,0003,0002 Boot0000* Windows Boot Manager HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)RC Boot0001* Windows Boot Manager HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(\EFI\ubuntu\grubx64.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000061000100000010000000040000007fff0400 Boot0002* Internal Hard Drive - ST1000LM035-1RK172 BBS(HD,Internal Hard Drive - ST1000LM035-1RK172,0x500)feff05000000000000000000000001062d0052e602000005190052e6410052e6000000020000000000000000000000000000000000000000000000000000000000d887c9ae110002010c00d041030a0000000001010600020801010600000003120a000000000000007fff0400 Boot0003* Internal Hard Drive - SanDisk SD9SN8W-128G-1006 BBS(HD,Internal Hard Drive - SanDisk SD9SN8W-128G-1006,0x500)feff05000000000000000000000001062d0059e602000005190059e6410059e6000000120000000000000000000000000000000000000000000000000000000000088ec9ae120002010c00d041030a0000000001010600020801010600000003120a000100000000007fff0400 Boot0005* Ubuntu HD(1,GPT,1695ed28-bfe9-4fc4-b2c2-bb0e33413587,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi) Boot2001* EFI USB Device RC Boot3000* Internal Hard Disk or Solid State Disk RC
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sdb : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, has-win, 2048 sectors * 512 bytes sda : is-GPT, no-BIOSboot, has-noESP, not-usb, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sdb5 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, end-after-100GB sdb4 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, end-after-100GB sdb3 : is-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sdb1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda2 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, no-grubenv, update-grub, end-after-100GB sda1 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, no-grubenv, update-grub, end-after-100GB
Partitions info (2/3): _________________________________________________________
sdb5 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ext4 sdb4 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, no-bmgr, notwinboot, ntfs sdb3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot, ntfs sdb1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, vfat sda2 : isnotESP, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ext4 sda1 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ext4
Partitions info (3/3): _________________________________________________________
sdb5 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sdb sdb4 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sdb3 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sdb1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sda2 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sda sda1 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors Disk identifier: E2203556-7D3B-43BA-827A-A667A7BEDB87 Start End Sectors Size Type sda1 977069282 1953520064 976450783 465.6G Linux filesystem sda2 618496 977069280 976450785 465.6G EFI System Partition table entries are not in disk order. Disk sdb: 119.24 GiB, 128035676160 bytes, 250069680 sectors Disk identifier: 9EDAE009-C871-4072-88DA-061A32150D06 Start End Sectors Size Type sdb1 2048 206847 204800 100M EFI System sdb2 206848 239615 32768 16M Microsoft reserved sdb3 239616 124617393 124377778 59.3G Microsoft basic data sdb4 248995840 250066943 1071104 523M Windows recovery environment sdb5 124617395 248995169 124377775 59.3G Linux filesystem Partition table entries are not in disk order.
parted -lm (filtered): _________________________________________________________
sda:1000GB:scsi:512:4096:gpt:ATA ST1000LM035-1RK1:; 2:317MB:500GB:500GB:ext4:lubuntu_2404:boot, esp; 1:500GB:1000GB:500GB:ext4:root:; sdb:128GB:scsi:512:4096:gpt:ATA SanDisk SD9SN8W-:; 1:1049kB:106MB:105MB:fat32:EFI system partition:boot, esp, no_automount; 2:106MB:123MB:16.8MB::Microsoft reserved partition:msftres, no_automount; 3:123MB:63.8GB:63.7GB:ntfs:Basic data partition:msftdata; 5:63.8GB:127GB:63.7GB:ext4:root:; 4:127GB:128GB:548MB:ntfs::hidden, diag, no_automount;
Free space >10MiB: ______________________________________________________________
sda: 0.02MiB:302MiB:302MiB
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda ├─sda1 ext4 940bd12b-0dc1-46ed-87fe-bfdb0eb9715a 0743ba8e-41a2-2348-a1b6-bd267db8e265 root └─sda2 ext4 2004cf58-df38-4ee0-9743-de134566f377 0a31c475-0ebc-43de-ae7e-da3195c5c047 lubuntu_2404 sdb ├─sdb1 vfat 98FB-4A13 1695ed28-bfe9-4fc4-b2c2-bb0e33413587 EFI system partition ├─sdb2 c060020c-f85c-4909-9707-34ddafa37d15 Microsoft reserved partition ├─sdb3 ntfs E4DC0031DC000092 e349bdfd-ec73-4acd-b521-94648fac4d18 SSD Basic data partition ├─sdb4 ntfs 3CF02F0CF02ECC48 d339b6c4-239c-4c12-9299-291012434792 └─sdb5 ext4 e473ae63-8a11-4c2d-bd34-b23b26bc9c0a c4d15a4d-60f5-b043-b259-8d25ca8ef7a1 root
Mount points (filtered): _______________________________________________________
                    Avail Use% Mounted on
/dev/sda1 427G 2% /mnt/boot-sav/sda1 /dev/sda2 425.9G 2% /mnt/boot-sav/sda2 /dev/sdb3 21.1G 64% /mnt/boot-sav/sdb3 /dev/sdb4 88.7M 83% /mnt/boot-sav/sdb4 /dev/sdb5 46.5G 15% / efivarfs 81.8K 46% /sys/firmware/efi/efivars
Mount options (filtered): ______________________________________________________
/dev/sda1 ext4 rw,relatime /dev/sda2 ext4 rw,relatime /dev/sdb3 fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 /dev/sdb4 fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 /dev/sdb5 ext4 rw,relatime,discard
========================== sda1/etc/fstab (filtered) ===========================
<file system> <mount point> <type> <options> <dump> <pass>
UUID=2004cf58-df38-4ee0-9743-de134566f377 /boot/efi ext4 umask=0077 0 2 UUID=940bd12b-0dc1-46ed-87fe-bfdb0eb9715a / ext4 defaults 0 1 /swapfile swap swap defaults 0 0
======================= sda1/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=0 GRUB_DISTRIBUTOR=lsb_release -i -s 2&gt; /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX=""
==================== sda1: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
469.502778053 = 504.124769280 boot/vmlinuz 1 469.502778053 = 504.124769280 boot/vmlinuz-6.8.0-40-generic 1 469.502778053 = 504.124769280 boot/vmlinuz.old 1 470.352887154 = 505.037566976 boot/initrd.img 1 470.352887154 = 505.037566976 boot/initrd.img-6.8.0-40-generic 1 470.352887154 = 505.037566976 boot/initrd.img.old 1
===================== sda1: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18683 Dec 18 2022 10_linux -rwxr-xr-x 1 root root 43031 Dec 18 2022 10_linux_zfs -rwxr-xr-x 1 root root 14387 Dec 18 2022 20_linux_xen -rwxr-xr-x 1 root root 13369 Dec 18 2022 30_os-prober -rwxr-xr-x 1 root root 1372 Dec 18 2022 30_uefi-firmware -rwxr-xr-x 1 root root 700 May 17 2023 35_fwupd -rwxr-xr-x 1 root root 214 Dec 18 2022 40_custom -rwxr-xr-x 1 root root 215 Dec 18 2022 41_custom
========================== sda2/etc/fstab (filtered) ===========================
UUID=2004cf58-df38-4ee0-9743-de134566f377 / ext4 defaults 0 1 /swapfile swap swap defaults 0 0
======================= sda2/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=0 GRUB_DISTRIBUTOR=( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2&gt;/dev/null || echo Ubuntu GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX=""
==================== sda2: Location of files loaded by Grub ====================
4.411827087 = 4.737163264 boot/vmlinuz 1 3.941654205 = 4.232318976 boot/vmlinuz-6.8.0-41-generic 1 4.411827087 = 4.737163264 boot/vmlinuz-6.8.0-47-generic 1 3.941654205 = 4.232318976 boot/vmlinuz.old 1 5.718132019 = 6.139797504 boot/initrd.img 2 4.046760559 = 4.345176064 boot/initrd.img-6.8.0-41-generic 1 5.718132019 = 6.139797504 boot/initrd.img-6.8.0-47-generic 2 4.046760559 = 4.345176064 boot/initrd.img.old 1
===================== sda2: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18133 Apr 4 2024 10_linux -rwxr-xr-x 1 root root 43202 Apr 4 2024 10_linux_zfs -rwxr-xr-x 1 root root 14513 Apr 4 2024 20_linux_xen -rwxr-xr-x 1 root root 786 Apr 4 2024 25_bli -rwxr-xr-x 1 root root 13120 Apr 4 2024 30_os-prober -rwxr-xr-x 1 root root 1174 Apr 4 2024 30_uefi-firmware -rwxr-xr-x 1 root root 722 Apr 5 2024 35_fwupd -rwxr-xr-x 1 root root 214 Apr 4 2024 40_custom -rwxr-xr-x 1 root root 215 Apr 4 2024 41_custom
===================== sdb1/efi/ubuntu/grub.cfg (filtered) ======================
search.fs_uuid e473ae63-8a11-4c2d-bd34-b23b26bc9c0a root hd1,gpt5 set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg
====================== sdb5/boot/grub/grub.cfg (filtered) ======================
Ubuntu e473ae63-8a11-4c2d-bd34-b23b26bc9c0a Ubuntu 22.04.5 LTS (22.04) (on sda1) 940bd12b-0dc1-46ed-87fe-bfdb0eb9715a Ubuntu 24.04.1 LTS (24.04) (on sda2) 2004cf58-df38-4ee0-9743-de134566f377 Windows Boot Manager (on sdb1) osprober-efi-98FB-4A13
END /etc/grub.d/30_os-prober
UEFI Firmware Settings uefi-firmware
END /etc/grub.d/30_uefi-firmware
========================== sdb5/etc/fstab (filtered) ===========================
UUID=e473ae63-8a11-4c2d-bd34-b23b26bc9c0a / ext4 defaults,discard 0 1 /swapfile swap swap defaults 0 0 tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0 UUID=98FB-4A13 /boot/efi vfat defaults 0 1
======================= sdb5/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=menu GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2&gt;/dev/null || echo Ubuntu GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX="" GRUB_DISABLE_OS_PROBER=false
==================== sdb5: Location of files loaded by Grub ====================
75.301396847 = 80.854259200 boot/grub/grub.cfg 1 62.162694454 = 66.746684928 boot/vmlinuz 1 65.865808010 = 70.722872832 boot/vmlinuz-6.8.0-40-generic 2 62.162694454 = 66.746684928 boot/vmlinuz-6.8.0-47-generic 1 65.865808010 = 70.722872832 boot/vmlinuz.old 2 76.000993252 = 81.605445120 boot/initrd.img 1 76.071313381 = 81.680950784 boot/initrd.img-6.8.0-40-generic 2 76.000993252 = 81.605445120 boot/initrd.img-6.8.0-47-generic 1 76.071313381 = 81.680950784 boot/initrd.img.old 2
===================== sdb5: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18133 Apr 4 2024 10_linux -rwxr-xr-x 1 root root 43202 Apr 4 2024 10_linux_zfs -rwxr-xr-x 1 root root 14513 Apr 4 2024 20_linux_xen -rwxr-xr-x 1 root root 786 Apr 4 2024 25_bli -rwxr-xr-x 1 root root 13120 Apr 4 2024 30_os-prober -rwxr-xr-x 1 root root 1174 Apr 4 2024 30_uefi-firmware -rwxr-xr-x 1 root root 722 Aug 21 20:39 35_fwupd -rwxr-xr-x 1 root root 214 Dec 18 2022 40_custom -rwxr-xr-x 1 root root 215 Dec 18 2022 41_custom
Alain Reve
  • 217
  • 18
