I'm attempting to install libncurses5-dev. When doing so, I get a strange error saying I have unmet dependencies:
Reading package lists... Done
Building dependency tree
Note, selecting 'libncurses5-dev' instead of 'libncurses-dev'
libncurses5-dev : Depends: libtinfo5 (= 6.1-1ubuntu1) but 6.1-1ubuntu1.18.04 is to be installed
Depends: libncurses5 (= 6.1-1ubuntu1) but 6.1-1ubuntu1.18.04 is to be installed
Depends: libtinfo-dev (= 6.1-1ubuntu1) but it is not going to be installed
When attempting to manually install all of the dependencies, most install fine, until I attempt to install libtinfo-dev, which has its own dependency that gives the exact same error.
libtinfo-dev: Depends: libtinfo5 (= 6.1-1ubuntu1) but 6.1-1ubuntu1.18.04 is to be installed.
When attempting to install this dependency manually, it shows me I have a version of it. However, when trying to install the specific version given, it cannot be found.
I am relatively new to all of this, so there may be something I am missing.
