This bug is a syntax error according to apt:
Preparing to unpack .../xdiagnose_3.8.12~24.04.1_all.deb ...
Unpacking xdiagnose (3.8.12~24.04.1) over (3.8.10) ...
Setting up xdiagnose (3.8.12~24.04.1) ...
/usr/lib/python3/dist-packages/xdiagnose/applet.py:185: SyntaxWarning: invalid escape sequence '\w'
re_kparam = re.compile("^([\w\.]+)=(.*)")
/usr/lib/python3/dist-packages/xdiagnose/applet.py:195: SyntaxWarning: invalid escape sequence '\w'
/usr/lib/python3/dist-packages/xdiagnose/applet.py:324: SyntaxWarning: invalid escape sequence '\['
re_xorg_error = re.compile("^\[\s*([\d\.]+)\] \(EE\) (.*)$")
/usr/lib/python3/dist-packages/xdiagnose/applet.py:325: SyntaxWarning: invalid escape sequence '\['
re_dmesg_error = re.compile("^\[\s*(\d+\.\d+)\] (.*(?:BUG|ERROR|WARNING).*)$")
/usr/lib/python3/dist-packages/xdiagnose/applet.py:326: SyntaxWarning: invalid escape sequence '\d'
re_jockey_error = re.compile("^(\d+\-\d+-\d+ \d+:\d+:\d+,\d+) ERROR: (.*)$")
/usr/lib/python3/dist-packages/xdiagnose/config_update.py:105: SyntaxWarning: invalid escape sequence '\s'
re_param = re.compile("^\s*(\w+)\s*"+delim+"\s*(.*)")
/usr/lib/python3/dist-packages/xdiagnose/config_update.py:133: SyntaxWarning: invalid escape sequence '\s'
p = re.compile("^\s*"+key+"\s*"+delim+"\s*(\"?)(.*)(\"?)")
/usr/lib/python3/dist-packages/xdiagnose/config_update.py:145: SyntaxWarning: invalid escape sequence '\s'
p = re.compile("^\s*"+key+"\s*"+delim)
/usr/lib/python3/dist-packages/xdiagnose/config_update.py:175: SyntaxWarning: invalid escape sequence '\o'
'BAR': 'f(1&&2*$i^2) # \o/',
/usr/lib/python3/dist-packages/xdiagnose/edid.py:67: SyntaxWarning: invalid escape sequence '\('
re_head = re.compile("\(II\) .*\(\d+\): EDID \(in hex\):$")
/usr/lib/python3/dist-packages/xdiagnose/edid.py:68: SyntaxWarning: invalid escape sequence '\('
re_edid = re.compile("\(II\) .*\(\d+\):\s\t([0-9a-f]{32})$")
/usr/lib/python3/dist-packages/xdiagnose/edid.py:287: SyntaxWarning: invalid escape sequence '\('
regex = re.compile("\(II\) .*\(\d+\):\s+(.*)$")
/usr/lib/python3/dist-packages/xdiagnose/pci_devices.py:97: SyntaxWarning: invalid escape sequence '\/'
PciDevice('i945g', '(8086:2772|945G[ \/])', [INTEL], gen='i945', opengl='1.4' ),
/usr/lib/python3/dist-packages/xdiagnose/pci_devices.py:99: SyntaxWarning: invalid escape sequence '\/'
PciDevice('i945gm', '(8086:27a2|945GM[ \/])', [INTEL], gen='i945', opengl='1.4' ),
/usr/lib/python3/dist-packages/xdiagnose/utils/config.py:16: SyntaxWarning: invalid escape sequence '\)'
'''Yet another INI-style config file parser.
/usr/lib/python3/dist-packages/xdiagnose/xorglog.py:94: SyntaxWarning: invalid escape sequence '\('
m = re.search('\(II\) Loading.*modules\/drivers\/(.+)_drv\.so', line)
Processing triggers for bamfdaemon (0.5.6+22.04.20220217-0ubuntu5) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils (0.27-2build1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) ...
Processing triggers for mate-menus (1.26.1-1build3) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
