Im currently trying to create a "shallow" backup of my whole filesystem, meaning that I should be able to somehow backup the current full filesystem structure, including mainly file ownerships and permissions, without the actual files contents for a fast "snapshot" of the filesystem in case I mess up the permissions at some later point, so I would be able to restore the ownerships and permissions recursively in such case.
The main objectives are:
  • The backup is very small in size since its only containing metadata (preferrably only ownership and permissions attributes)
  • The backup is fast(er) to create compared to an actual backup
  • The backup should be able to be restored 1:1 to the original target (ignoring new files missing from the backup)
Would this be possible e.g. using rsync, tar or similar tools?
A similar question was asked here.
However, Im looking for a full/comprehensive solution to the problem and objectives described.
Sinipelto
  • 137
I can try to answer the question myself. This answer probably requires corrections.
To backup the a directory, attributes only recursively and preservatively, and using tar to store the resulting structure in a single file, one can use:
[sudo] cp -rT --attributes-only --preserve=mode,ownership /path/to/source /path/to/dest
[sudo] tar -C / -cf /path/to/backup.tar /path/to/dest
And to restore, use reverse approach:
[sudo] tar -C / -xf /path/to/backup.tar
[sudo] cp -rT --attributes-only --preserve=mode,ownership /path/to/dest /path/to/source
Root/sudo required to preserve
Sinipelto
  • 137
