Ever since updating to Ubuntu 24.04.1 LTS I've been unable to make any updates, install new apps, or even remove old apps.
Everything errors out saying "unmet dependencies."
Even when I try to repair the packages system I get an error saying it can't stop mysql because it's not loaded.
sudo apt --fix-broken install returns the following.
Reading package lists... Done
Building dependency tree... Done
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
acpi-support acpid aisleriot apturl apturl-common branding-ubuntu cheese
cheese-common chromium-codecs-ffmpeg-extra cpp-11 endeavour endeavour-common
fonts-kacst fonts-kacst-one fonts-khmeros-core fonts-lao fonts-liberation2
fonts-lklug-sinhala fonts-sil-abyssinica fonts-sil-padauk fonts-thai-tlwg
fonts-tibetan-machine fonts-tlwg-garuda fonts-tlwg-garuda-ttf
fonts-tlwg-kinnari fonts-tlwg-kinnari-ttf fonts-tlwg-laksaman
fonts-tlwg-laksaman-ttf fonts-tlwg-loma fonts-tlwg-loma-ttf fonts-tlwg-mono
fonts-tlwg-mono-ttf fonts-tlwg-norasi fonts-tlwg-norasi-ttf
fonts-tlwg-purisa fonts-tlwg-purisa-ttf fonts-tlwg-sawasdee
fonts-tlwg-sawasdee-ttf fonts-tlwg-typewriter fonts-tlwg-typewriter-ttf
fonts-tlwg-typist fonts-tlwg-typist-ttf fonts-tlwg-typo fonts-tlwg-typo-ttf
fonts-tlwg-umpush fonts-tlwg-umpush-ttf fonts-tlwg-waree
fonts-tlwg-waree-ttf gcc-11 gcc-11-base gcc-12-base:i386 gedit gedit-common
genisoimage gir1.2-amtk-5 gir1.2-appindicator3-0.1 gir1.2-gck-1 gir1.2-gcr-3
gir1.2-goa-1.0 gir1.2-gtksource-300 gir1.2-gtksource-4 gir1.2-gweather-3.0
gir1.2-javascriptcoregtk-4.0 gir1.2-json-1.0 gir1.2-nma-1.0 gir1.2-snapd-1
gir1.2-soup-2.4 gir1.2-tepl-6 gir1.2-webkit2-4.0 gnome-bluetooth
gnome-bluetooth-common gnome-mahjongg gnome-mines gnome-sudoku gnome-todo
gnome-video-effects gsfonts gstreamer1.0-clutter-3.0 guile-2.2-libs
guile-3.0-libs irqbalance libabsl20210324 libapache2-mod-php libappstream4
libasan6 libatk1.0-data libavcodec58 libavfilter7 libavformat58 libavutil56
libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2 libblockdev-part-err2
libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2
libboost-filesystem1.74.0 libboost-iostreams1.74.0 libboost-locale1.74.0
libboost-python1.74.0 libboost-python1.83.0 libboost-regex1.74.0
libboost-thread1.74.0 libbpf0 libcamel-1.2-63 libcbor0.8 libcheese-gtk25
libcheese8 libclutter-1.0-0 libclutter-1.0-common libclutter-gst-3.0-0
libclutter-gtk-1.0-0 libcodec2-1.0 libcogl-common libcogl-pango20
libcogl-path20 libcogl20 libcolamd2 libcolord-gtk1t64 libcupsfilters1
libdav1d5 libdazzle-1.0-0 libdazzle-common libdmapsharing-3.0-2
libdns-export1110 libebackend-1.2-10 libebook-1.2-20 libebook-contacts-1.2-3
libecal-2.0-1 libedata-book-1.2-26 libedata-cal-2.0-1 libedataserver-1.2-26
libedataserverui-1.2-3 libflac8 libfontembed1 libfreerdp-client2-2t64
libfreerdp-server2-2t64 libfreerdp2-2t64 libgc1 libgcab-1.0-0 libgcc-11-dev
libgedit-amtk-5-0 libgedit-amtk-5-common libgedit-gtksourceview-300-0
libgedit-gtksourceview-300-common libgeocode-glib0 libgfapi0 libgfrpc0
libgfxdr0 libglusterfs0 libgnome-bluetooth13t64 libgnome-games-support-1-3
libgnome-games-support-common libgnome-todo libgoa-backend-1.0-1
libgssdp-1.2-0 libgtksourceview-4-0 libgtksourceview-4-common libgupnp-1.2-1
libgweather-3-16 libgweather-common libicu70 libilmbase25 libisc-export1105
libjavascriptcoregtk-4.0-18 libldap-2.5-0 libllvm15t64 liblua5.3-0
libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickwand-6.q16-6
libmessaging-menu0 libmozjs-91-0 libmpdec3 libnautilus-extension1a
libnetpbm10 libnetplan0 libnfs13 libnsl-dev libopencore-amrnb0
libopencore-amrwb0 libopenexr25 liborcus-0.17-0 liborcus-parser-0.17-0
libpcre3 libperl5.34 libplist3 libpoppler118 libpostproc55 libprotobuf23
libpython3.10 libpython3.10-minimal libpython3.10-stdlib libqpdf28
libqqwing2v5 libraw20 libreoffice-pdfimport librest-0.7-0
librygel-core-2.6-2 librygel-db-2.6-2 librygel-renderer-2.6-2
librygel-server-2.6-2 libsmbios-c2 libsnapd-glib1 libsoup-gnome-2.4-1
libsrt1.4-gnutls libsuitesparseconfig5 libswresample3 libswscale5
libtepl-6-4 libtepl-common libtiff5 libtirpc-dev libtorrent-rasterbar2.0t64
libtsan0 libunistring2 libunistring2:i386 libvncserver1 libvpx7
libwebkit2gtk-4.0-37 libwinpr2-2t64 libx264-163 linux-headers-5.15.0-122
linux-headers-5.15.0-122-generic linux-hwe-6.8-headers-6.8.0-40
linux-hwe-6.8-headers-6.8.0-45 linux-hwe-6.8-tools-6.8.0-40
linux-hwe-6.8-tools-6.8.0-45 linux-image-5.15.0-122-generic
linux-modules-5.15.0-122-generic linux-modules-extra-5.15.0-122-generic
nautilus-share perl-modules-5.34 python3-future python3-lib2to3
python3-libtorrent python3-lockfile python3-macaroonbakery python3-protobuf
python3-pyatspi python3-pymacaroons python3-requests-toolbelt
python3-rfc3339 python3.10 python3.10-minimal ubuntu-advantage-tools
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
mariadb-server
Suggested packages:
mailx mariadb-test
The following packages will be upgraded:
mariadb-server
1 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
5 not fully installed or removed.
Need to get 0 B/3,381 kB of archives.
After this operation, 55.4 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Preconfiguring packages ...
(Reading database ... 343792 files and directories currently installed.)
Preparing to unpack .../mariadb-server_1%3a10.11.8-0ubuntu0.24.04.1_amd64.deb ..
Failed to stop mysql.service: Unit mysql.service not loaded.
invoke-rc.d: initscript mysql, action "stop" failed.
Attempt to stop MariaDB/MySQL server returned exitcode 5
There is a MariaDB/MySQL server running, but we failed in our attempts to stop i
t.
Stop it yourself and try again!
dpkg: error processing archive /var/cache/apt/archives/mariadb-server_1%3a10.11.
8-0ubuntu0.24.04.1_amd64.deb (--unpack):
new mariadb-server package pre-installation script subprocess returned error ex
it status 1
/var/cache/apt/archives/mariadb-server_1%3a10.11.8-0ubuntu0.24.04.1_amd64.deb
I've tried purging mysql and mariadb both several times, and nothing works.
I've been at this every night for a week and can't get anything to fix it. I'm about to just reinstall, but I'd much rather figure out how to fix it.
