Possible Duplicate:
Software center not opening
When opening software center, the operation is stuck after opening the window and upper bar. The error message when launching from terminal is:
2012-06-19 12:53:33,684 - softwarecenter.backend.reviews - WARNING - Could not get usefulness from server, no username in config file
ofer
  • 31
The OP solved this by opening the terminal with Ctrl+Alt+T and typing:
rm -r ~/.cache/software-center
  • When doing this, it's very important to not accidentally have a space after ~ or the first /. If you do, it will remove all the files in your home directory, which generally includes all your documents!
  • An alternative command to run, which doesn't turn into such a bad thing when typed slightly wrong, is this:
    cd ~/.cache; rm -r software-center
Eliah Kagan
  • 119,640
ish
  • 141,990
