Completely modifying my question as I've figured out where the power consumption is coming from
Ubuntu is draining the battery really fast, apparently due to something called "Kwork":
Summary: 2332.8 wakeups/second,  0.0 GPU ops/seconds, 0.0 VFS ops/sec and 2450.4
            Usage       Events/s    Category       Description
        24227 ms/s       4.2        kWork          acpi_os_execute_deferred
          4.8 ms/s     656.0        Timer          tick_nohz_handler
         15.2 ms/s     279.4        Process        [PID 6400] /app/brave/bra
         11.3 ms/s     207.4        Interrupt      [7] sched(softirq)
          2.4 ms/s     123.8        Interrupt      [6] AMDI0010:03
          4.4 ms/s     107.0        Process        [PID 3013] /usr/lib/xorg/
          4.6 ms/s      87.0        Interrupt      [77] amdgpu
          1.2 ms/s      86.6        Process        [PID 948] [irq/76-rtw89_p
          4.6 ms/s      74.7        Interrupt      [3] net_rx(softirq)
          7.8 ms/s      65.9        Process        [PID 3307] /usr/bin/gnome
         11.1 ms/s      63.0        Process        [PID 4251] /app/brave/bra
          3.3 ms/s      53.8        Process        [PID 4580] /app/brave/bra
          6.1 ms/s      52.4        Process        [PID 4491] /app/brave/bra
          1.3 ms/s      38.0        Process        [PID 4576] /app/brave/bra
          1.3 ms/s      29.7        Process        [PID 4471] /app/brave/bra
        314.6 µs/s      29.2        Process        [PID 17] [rcu_preempt]
          1.9 ms/s      23.8        Process        [PID 3603] /usr/libexec/i
Thoughts on how to proceed to debug? Interestingly enough, when on AC power, KWork is all the way down in power usage.
Here are the interrupts when running grep . -r /sys/firmware/acpi/interrupts/, I get:
/sys/firmware/acpi/interrupts/gpe1F:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe13:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe0F:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe03:       0     STS invalid      unmasked
/sys/firmware/acpi/interrupts/gpe1D:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/ff_pwr_btn:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe11:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe0D:       0         disabled     unmasked
/sys/firmware/acpi/interrupts/gpe01:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/ff_rt_clk:       0         disabled     unmasked
/sys/firmware/acpi/interrupts/ff_pmtimer:       0     STS invalid      unmasked
/sys/firmware/acpi/interrupts/gpe1B:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe0B:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe18:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe08:       0         disabled     unmasked
/sys/firmware/acpi/interrupts/error:       0
/sys/firmware/acpi/interrupts/gpe16:       0     STS invalid      unmasked
/sys/firmware/acpi/interrupts/sci:   56257
/sys/firmware/acpi/interrupts/gpe06:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe14:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe04:       0  EN     enabled      unmasked
/sys/firmware/acpi/interrupts/gpe1E:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe12:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe0E:       0         disabled     unmasked
/sys/firmware/acpi/interrupts/gpe02:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe1C:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe10:       0  EN     enabled      unmasked
/sys/firmware/acpi/interrupts/gpe0C:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe00:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe_all:   56257
/sys/firmware/acpi/interrupts/gpe19:       0         disabled     unmasked
/sys/firmware/acpi/interrupts/gpe1A:       0         disabled     unmasked
/sys/firmware/acpi/interrupts/gpe09:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe0A:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe17:   56257  EN     enabled      unmasked
/sys/firmware/acpi/interrupts/ff_gbl_lock:       0  EN     enabled      unmasked
/sys/firmware/acpi/interrupts/gpe07:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/sci_not:       0
/sys/firmware/acpi/interrupts/gpe15:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/gpe05:       0         invalid      unmasked
/sys/firmware/acpi/interrupts/ff_slp_btn:       0         invalid      unmasked
ChatGPT suggested me to check the contents of dmesg | grep -i error :
[    0.576154] RAS: Correctable Errors collector initialized.
[    5.978388] ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
Also, the contents of dmesg | tail -n 50 :
[    5.978380] ucsi_acpi USBC000:00: failed to reset PPM!
[    6.552774] rfkill: input handler disabled
[    6.707445] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[    8.774245] wlo1: authenticate with 98:52:4a:4b:c5:59 (local address=94:bb:43:26:56:e8)
[    8.774254] wlo1: send auth to 98:52:4a:4b:c5:59 (try 1/3)
[    8.775342] wlo1: authenticated
[    8.777395] wlo1: associate with 98:52:4a:4b:c5:59 (try 1/3)
[    8.780430] wlo1: RX AssocResp from 98:52:4a:4b:c5:59 (capab=0x1511 status=0 aid=2)
[    8.890917] wlo1: associated
[    8.890949] wlo1: Limiting TX power to 30 (30 - 0) dBm as advertised by 98:52:4a:4b:c5:59
[    9.667528] rfkill: input handler enabled
[   10.110709] kauditd_printk_skb: 131 callbacks suppressed
[   10.110713] audit: type=1400 audit(1728738854.105:142): apparmor="ALLOWED" operation="mknod" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[   10.110804] audit: type=1400 audit(1728738854.105:143): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="rc" denied_mask="rc" fsuid=1000 ouid=1000
[   10.110811] audit: type=1400 audit(1728738854.105:144): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[   10.110816] audit: type=1400 audit(1728738854.105:145): apparmor="ALLOWED" operation="mknod" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[   10.110819] audit: type=1400 audit(1728738854.105:146): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="rc" denied_mask="rc" fsuid=1000 ouid=1000
[   10.110823] audit: type=1400 audit(1728738854.105:147): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="wr" denied_mask="wr" fsuid=1000 ouid=1000
[   10.110826] audit: type=1400 audit(1728738854.105:148): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[   10.110829] audit: type=1400 audit(1728738854.105:149): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[   10.110833] audit: type=1400 audit(1728738854.105:150): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   10.111069] audit: type=1400 audit(1728738854.105:151): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   10.776074] NFSD: Using nfsdcld client tracking operations.
[   10.776079] NFSD: no clients to reclaim, skipping NFSv4 grace period (net f0000000)
[   11.707635] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   11.825880] rfkill: input handler disabled
[   14.391898] warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   64.526643] kauditd_printk_skb: 1176 callbacks suppressed
[   64.526648] audit: type=1400 audit(1728738909.016:1328): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg:sh0" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[   64.526653] audit: type=1400 audit(1728738909.016:1329): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg:sh0" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[   64.526664] audit: type=1400 audit(1728738909.016:1330): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg:sh0" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   64.526677] audit: type=1400 audit(1728738909.016:1331): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg:sh0" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   64.526707] audit: type=1400 audit(1728738909.016:1332): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg:sh0" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   64.526718] audit: type=1400 audit(1728738909.016:1333): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg:sh0" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   64.526727] audit: type=1400 audit(1728738909.016:1334): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg:sh0" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   64.526737] audit: type=1400 audit(1728738909.016:1335): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg:sh0" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   64.526750] audit: type=1400 audit(1728738909.016:1336): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg:sh0" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   64.526767] audit: type=1400 audit(1728738909.016:1337): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg:sh0" requested_mask="w" denied_mask="w" fsuid=1000 ouid=1000
[   77.960428] kauditd_printk_skb: 214 callbacks suppressed
[   77.960433] audit: type=1400 audit(1728738922.271:1552): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[   77.960439] audit: type=1400 audit(1728738922.271:1553): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=1000 ouid=1000
[   77.960442] audit: type=1400 audit(1728738922.271:1554): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   77.960451] audit: type=1400 audit(1728738922.271:1555): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   77.960470] audit: type=1400 audit(1728738922.271:1556): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   77.960477] audit: type=1400 audit(1728738922.271:1557): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   77.960479] audit: type=1400 audit(1728738922.271:1558): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   77.960488] audit: type=1400 audit(1728738922.271:1559): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   77.960496] audit: type=1400 audit(1728738922.271:1560): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[   77.960503] audit: type=1400 audit(1728738922.271:1561): apparmor="ALLOWED" operation="file_perm" class="file" profile="Xorg" name="/home/evan/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=2386 comm="Xorg" requested_mask="w" denied_mask="w" fsuid=1000 ouid=1000
Also note that no matter if on AC Power or Battery power, one of my CPU threads is always running around 98%. Also note that I am on powersave governor.
Evanbb8
