I'm on Kubuntu 24.04.1 and I've managed to succesfully mount a smb share with cifs by adding it in /etc/fstab, with this line:
//192.168.10.122/Test /mnt/Test cifs user,noauto,user=test,password=test 0 0
The problem is that the password is in plain text which is not secure. So I've followed a new guide, by creating a credential file (.smb_cred) with chmod 600 (read and write) and put this line instead:
//192.168.10.122/Test /mnt/Test cifs uid=1000,credentials=/home/test/.smb_cred,iocharset=utf8 0 0
The problem is that it doesn't work. I see the mounted file but it's empty.
muru
  • 207,228
Gamix
It's not automounting since you specified noauto in the declare statement. You have given a non-root user the ability to mount it however with the preceding user option.
That line is attempting to do the opposite. It's attempting to automatically mount the share at boot time.
After a reboot if the share doesn't mount open a terminal and run:
sudo mount -a
If the share is now mounted you can either:
  1. Incorporate the user,noauto method you used in the first declaration:
    //192.168.10.122/Test /mnt/Test cifs user,noauto,uid=1000,credentials=/home/test/.smb_cred 0 0
  2. Or, use a systemd automounter: x-systemd.automount:
    //192.168.10.122/Test /mnt/Test cifs uid=1000,credentials=/home/test/.smb_cred,iocharset=utf8,x-systemd.automount 0 0
Note: If you have an encrypted home directory the credentials file needs to be someplace else like /etc/samba/cred-files/.smb_cred
muru
  • 207,228
Morbius1
  • 8,437
