I'm experiencing problems installing VirtualBox 7.1.2 for Linux. After downloading the latest version for Ubuntu 22.04 from Virtual Box website and using dpkg -i virtualbox-7.1_7.1.2-164945~Ubuntu~jammy_amd64.deb command the terminal showed this error.
tomas@tomas-efficast:~/Downloads$ sudo dpkg -i virtualbox-7.1_7.1.2-
Selecting previously unselected package virtualbox-7.1.
(Reading database ... 224150 files or directories currently installed.)
Preparing to unpack virtualbox-7.1_7.1.2-164945~Ubuntu~jammy_amd64.deb ...
Unpacking virtualbox-7.1 (7.1.2-164945~Ubuntu~jammy) ...
dpkg: dependency problems prevent configuration of virtualbox-7.1:
virtualbox-7.1 depends on libxcb-cursor0 (>= 0.0.99); however:
The package `libxcb-cursor0' is not installed.
dpkg: error processing package virtualbox-7.1 (--install): dependency problems - leaving configured Processing triggers for libc-bin (2.35-0ubuntu3.8) ... Processing triggers for mailcap (3.70+nmu1ubuntu1) ... Processing triggers for gnome-menus (3.36.0-1ubuntu3) ... Processing triggers for desktop-file-utils (0.26-1ubuntu3) ... Processing triggers for hicolor-icon-theme (0.17-2) ... Processing triggers for shared-mime-info (2.1-2) ... Errors were encountered while processing: virtualbox-7.1
I tried using sudo apt-get purge "^virtualbox-.*" then sudo apt-get autoremove && sudo apt-get autoclean && sudo apt-get clean for cleaning the packages but I received the same error.
I would appreciate any suggestions or possible solutions.
This might do the trick before you try installing again.
apt install libxcb-cursor0
Then try the install again. If that doesn't help, try the following method.
To make upgrading to later versions of Virtualbox much easier, I use the following method... it is not command line, but it works smoothly.
  1. use 'synaptic package manager' to search for and then remove the old
    install.
  2. download the new install from the VB website
  3. use 'gnome software' to open the new package and install it.
  4. then install the extension pack from within 'files'.
