After booting up I was met with a black screen. I was able to access the command line and after changing the GRUB_CMDLINE_LINUX_DEFAULT (now I don't remember if I added nomodeset or removed it), I got a low resolution display at 640x480.
I search online and tried to used ubuntu-drivers to no avail. Then by running inxi (check the output bellow) I inferred that the issue must be with my integrated card not loading the i915 driver.
I know it's not an hardware problem because I booted Ubuntu 24 from a live USB and there was no resolution problem and i915was loading properly. For references I've copied the output of inxi in the same system with the live USB Ubuntu (see bellow)
I don't know much about Linux and I don't know if the issue might be of some X server vs Wayland issue because I tried to have both installed so that I could change between them; or some display manager issue.
I would be really grateful for any help, this system has proprietary software so I would like to avoid a clean install.
Update: I was able see the Ubuntu logo and then I got to a black screen with visible cursor using Kernel 6.8.0-45-generic. If I go to the terminal and try to startx, I get an error
xf86EnableIO: failed to enable I/O port 0000-03ff (Operation not permitted)
The surprising thing is that sudo startx works and leads me to the correct resolution.
Faulty system:
System:
Host: joachim-HP-EliteDesk-800-G1-SFF
Kernel: 6.11.0-061100-generic arch: x86_64 bits: 64
Desktop: GNOME v: 46.0 Distro: Ubuntu 24.04.1 LTS
(Noble Numbat)
Machine:
Type: Desktop System: Hewlett-Packard
product: HP EliteDesk 800 G1 SFF v: N/A
serial: <superuser required>
Mobo: Hewlett-Packard model: 1998
serial: <superuser required> UEFI: Hewlett-Packard
v: L01 v02.78 date: 02/20/2020
CPU:
Info: quad core model: Intel Core i5-4570 bits: 64
type: MCP cache: L2: 1024 KiB
Speed (MHz): avg: 1095 min/max: 800/3600 cores: 1: 1987
2: 798 3: 798 4: 800
Graphics:
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor
Integrated Graphics driver: N/A
Device-2: Sunplus Innovation HD 720P webcam
driver: snd-usb-audio,uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.11 with: Xwayland
v: 23.2.6 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: swrast gpu: N/A
resolution: 640x480~60Hz
API: EGL v: 1.5 drivers: kms_swrast,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.5 vendor: mesa v: 24.0.9-0ubuntu0.1
renderer: llvmpipe (LLVM 17.0.6 256 bits)
Live USB system:
System:
Host: ubuntu Kernel: 6.8.0-41-generic arch: x86_64 bits: 64
Desktop: GNOME v: 46.0 Distro: Ubuntu 24.04.1 LTS (Noble Numbat)
Machine:
Type: Desktop System: Hewlett-Packard product: HP EliteDesk 800 G1 SFF
v: N/A serial: <superuser required>
Mobo: Hewlett-Packard model: 1998 serial: <superuser required>
UEFI: Hewlett-Packard v: L01 v02.78 date: 02/20/2020
CPU:
Info: quad core model: Intel Core i5-4570 bits: 64 type: MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 1739 min/max: 800/3600 cores: 1: 1957 2: 1008 3: 800
4: 3193
Graphics:
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
driver: i915 v: kernel
Device-2: Sunplus Innovation HD 720P webcam driver: snd-usb-audio,uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915 resolution:
1: 1280x1024~60Hz 2: 1280x1024~60Hz
API: EGL v: 1.5 drivers: crocus,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.1
renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
Edit: Added the same inxi output on the same system with the Ubuntu from the live USB.
