I had asked this question in podman discussion on Github (see the post here) but no luck getting an answer. So I copy the content and turn to ask Ubuntu for help. I hope that in a more general site with more users the comments and answers may solve my problem or lead me to somewhere nearer to the target.
I want to configure podman to provide a shared image storage between root-less users within the host but failed. I don't care if root user works.
user0 is sudo user, user1 and user2 are root-less users. All shells are ssh-ed with corresponding username directly (i.e. not by su).
- user1 output
user1@test:~$ podman images
REPOSITORY TAG IMAGE ID CREATED SIZE
user1@test:~$ podman pull busybox
Resolving "busybox" using unqualified-search registries (/etc/containers/registries.conf)
Trying to pull gitea.cn:666/busybox:latest...
Getting image source signatures
Copying blob a10d77880eaf done
Copying config 87ff76f62d done
Writing manifest to image destination
Storing signatures
87ff76f62d367950186bde563642e39208c0e2b4afc833b4b3b01b8fef60ae9e
user1@test:~$ podman images --log-level=debug
INFO[0000] podman filtering at log level debug
DEBU[0000] Called images.PersistentPreRunE(podman images --log-level=debug)
DEBU[0000] overlay storage already configured with a mount-program
DEBU[0000] Merged system config "/usr/share/containers/containers.conf"
DEBU[0000] Using conmon: "/usr/bin/conmon"
DEBU[0000] Initializing boltdb state at /var/lib/sharedimages/libpod/bolt_state.db
DEBU[0000] Overriding run root "/run/user/1001" with "/run/user/1001/containers" from database
DEBU[0000] systemd-logind: Unknown object '/'.
DEBU[0000] Using graph driver overlay
DEBU[0000] Using graph root /var/lib/sharedimages
DEBU[0000] Using run root /run/user/1001/containers
DEBU[0000] Using static dir /var/lib/sharedimages/libpod
DEBU[0000] Using tmp dir /run/user/1001/libpod/tmp
DEBU[0000] Using volume path /var/lib/sharedimages/volumes
DEBU[0000] Set libpod namespace to ""
DEBU[0000] [graphdriver] trying provided driver "overlay"
DEBU[0000] cached value indicated that overlay is supported
DEBU[0000] cached value indicated that metacopy is not being used
DEBU[0000] cached value indicated that native-diff is usable
DEBU[0000] backingFs=extfs, projectQuotaSupported=false, useNativeDiff=true, usingMetacopy=false
DEBU[0000] Initializing event backend journald
DEBU[0000] configured OCI runtime runc initialization failed: no valid executable found for OCI runtime runc: invalid argument
DEBU[0000] configured OCI runtime kata initialization failed: no valid executable found for OCI runtime kata: invalid argument
DEBU[0000] configured OCI runtime runsc initialization failed: no valid executable found for OCI runtime runsc: invalid argument
DEBU[0000] Using OCI runtime "/usr/bin/crun"
INFO[0000] Found CNI network podman (type=bridge) at /home/user1/.config/cni/net.d/87-podman.conflist
DEBU[0000] Default CNI network name podman is unchangeable
INFO[0000] Setting parallel job count to 37
DEBU[0000] parsed reference into "[overlay@/var/lib/sharedimages+/run/user/1001/containers]@87ff76f62d367950186bde563642e39208c0e2b4afc833b4b3b01b8fef60ae9e"
DEBU[0000] exporting opaque data as blob "sha256:87ff76f62d367950186bde563642e39208c0e2b4afc833b4b3b01b8fef60ae9e"
gitea.cn:666/busybox latest 87ff76f62d36 16 months ago 4.5 MB
DEBU[0000] Called images.PersistentPostRunE(podman images --log-level=debug)
user1@test:~$
- user2 output
user2@test:~$ podman images --log-level=debug
DEBU[0000] Overriding run root "/run/user/1002" with "/run/user/1001/containers" from database
DEBU[0000] Overriding tmp dir "/run/user/1002/libpod/tmp" with "/run/user/1001/libpod/tmp" from database
WARN[0000] XDG_RUNTIME_DIR is pointing to a path which is not writable. Most likely podman will fail.
DEBU[0000] Not configuring container store
Error: error creating tmpdir: mkdir /run/user/1001/libpod: permission denied
user2@test:~$
The configurations:
- user1
user1@test:~$ more /home/user1/.config/containers/storage.conf
[storage]
driver = "overlay"
runroot = "/run/user/1001"
graphroot = "/var/lib/sharedimages"
user1@test:~$ id
uid=1001(user1) gid=1001(user1) groups=1001(user1)
user1@test:~$
- user2
user2@test:~$ more /home/user2/.config/containers/storage.conf
[storage]
driver = "overlay"
runroot = "/run/user/1002"
[storage.options]
mount_program = "/bin/fuse-overlayfs"
user2@test:~$ id
uid=1002(user2) gid=1002(user2) groups=1002(user2)
- user0: no configuration
user0@test:/home/user1$ cd /etc/containers/
user0@test:/etc/containers$ ls
libpod.conf policy.json registries.conf registries.conf.d
user0@test:/etc/containers$ id
uid=1000(user0) gid=1000(user0) groups=1000(user0),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),110(lxd)
- The podman version
user1@test:~$ podman version
Version: 3.4.4
API Version: 3.4.4
Go Version: go1.18.1
Built: Thu Jan 1 00:00:00 1970
OS/Arch: linux/amd64
- The podman info
user1@test:~$ podman info
host:
arch: amd64
buildahVersion: 1.23.1
cgroupControllers:
- memory
- pids
cgroupManager: systemd
cgroupVersion: v2
conmon:
package: 'conmon: /usr/bin/conmon'
path: /usr/bin/conmon
version: 'conmon version 2.0.25, commit: unknown'
cpus: 12
distribution:
codename: jammy
distribution: ubuntu
version: "22.04"
eventLogger: journald
hostname: test
idMappings:
gidmap:
- container_id: 0
host_id: 1001
- container_id: 1
host_id: 165536
uidmap:
- container_id: 0
host_id: 1001
- container_id: 1
host_id: 165536
kernel: 5.15.0-122-generic
linkmode: dynamic
logDriver: journald
memFree: 19415232512
memTotal: 20680478720
ociRuntime:
package: 'crun: /usr/bin/crun'
path: /usr/bin/crun
version: |-
crun version 0.17
commit: 0e9229ae34caaebcb86f1fde18de3acaf18c6d9a
spec: 1.0.0
+SYSTEMD +SELINUX +APPARMOR +CAP +SECCOMP +EBPF +YAJL
os: linux
remoteSocket:
exists: true
path: /run/user/1001/podman/podman.sock
security:
apparmorEnabled: false
capabilities: CAP_CHOWN,CAP_DAC_OVERRIDE,CAP_FOWNER,CAP_FSETID,CAP_KILL,CAP_NET_BIND_SERVICE,CAP_SETFCAP,CAP_SETGID,CAP_SETPCAP,CAP_SETUID,CAP_SYS_CHROOT
rootless: true
seccompEnabled: true
seccompProfilePath: /usr/share/containers/seccomp.json
selinuxEnabled: false
serviceIsRemote: false
slirp4netns:
executable: /usr/bin/slirp4netns
package: 'slirp4netns: /usr/bin/slirp4netns'
version: |-
slirp4netns version 1.0.1
commit: 6a7b16babc95b6a3056b33fb45b74a6f62262dd4
liuser0irp: 4.6.1
swapFree: 8589930496
swapTotal: 8589930496
uptime: 13h 8m 55.68s (Approximately 0.54 days)
plugins:
log:
- k8s-file
- none
- journald
network:
- bridge
- macvlan
volume:
- local
registries:
search:
- gitea.cn:666
store:
configFile: /home/user1/.config/containers/storage.conf
containerStore:
number: 0
paused: 0
running: 0
stopped: 0
graphDriverName: overlay
graphOptions: {}
graphRoot: /var/lib/sharedimages
graphStatus:
Backing Filesystem: extfs
Native Overlay Diff: "true"
Supports d_type: "true"
Using metacopy: "false"
imageStore:
number: 1
runRoot: /run/user/1001/containers
volumePath: /var/lib/sharedimages/volumes
version:
APIVersion: 3.4.4
Built: 0
BuiltTime: Thu Jan 1 00:00:00 1970
GitCommit: ""
GoVersion: go1.18.1
OsArch: linux/amd64
Version: 3.4.4
- The OS
user1@test:~$ uname -a
Linux test 5.15.0-122-generic #132-Ubuntu SMP Thu Aug 29 13:45:52 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
Seemed the debug log said the configuration of user2 did not take effect
Then what's the expected configurations for this requirement?
Thank you very much!
Edit on 29th Sep.
I removed podman -> removed /var/lib/sharedimages -> removed /var/lib/containers -> removed /home/user1/.config/containers/storage.conf -> removed /home/user2/.config/container/stoarge.conf -> reboot host -> reinstalled podman -> recreated /var/lib/sharedimages and /var/lib/container
- try user2 first
DEBU[0000] Initializing boltdb state at /home/user2/.local/share/containers/storage/libpod/bolt_state.db
DEBU[0000] Using graph root /home/user2/.local/share/containers/storage
DEBU[0000] Using run root /run/user/1002/containers
DEBU[0000] Using static dir /home/user2/.local/share/containers/storage/libpod
DEBU[0000] Using tmp dir /run/user/1002/libpod/tmp
DEBU[0000] Using volume path /home/user2/.local/share/containers/storage/volumes
DEBU[0000] overlay: mount_program=/usr/bin/fuse-overlayfs
DEBU[0000] backingFs=extfs, projectQuotaSupported=false, useNativeDiff=false, usingMetacopy=false
INFO[0000] Found CNI network podman (type=bridge) at /home/user2/.config/cni/net.d/87-podman.conflist
user2@test:~$
Then user1
Error: error creating runtime static files directory: mkdir /var/lib/sharedimages/libpod: permission denied
user1@test:~$
user1@test:~$
user1@test:~$ more .config/c
cni/ containers/
user1@test:~$ more .config/containers/storage.conf
[storage]
driver = "overlay"
[storage.options]
