I'm trying to upgrade my Ubuntu Studio from 23.10 to 24.04.1 but I get this error message:
Unable to determine which system updates are available
An unresolvable problem occurred while calculating the system update.
It is suggested to have a look at »/var/log/dist-upgrade« main.log and apt.log which will be attached later.
I could not find anything for missing packages. There are some where they "failed to find a replacement" but have a look yourself:
I couln't fit the whole main.log in so here are some errors I found:
2024-09-28 13:17:48,236 DEBUG Searching for replacement for libiw30
2024-09-28 13:17:48,237 DEBUG Failed to find a replacement for libiw30
2024-09-28 13:17:57,121 DEBUG Searching for replacement for libpython3.11-minimal
2024-09-28 13:17:57,121 DEBUG Failed to find a replacement for libpython3.11-minimal
And in apt.log I found this and also other errors:
Broken coreutils:amd64 Beschädigt on usrmerge:amd64 < 35ubuntu1 @ii mK > (< 39)
Considering usrmerge:amd64 -3 as a solution to coreutils:amd64 5110
Added usrmerge:amd64 to the remove list
MarkDelete usrmerge:amd64 < 35ubuntu1 @ii mK > FU=0
Fixing coreutils:amd64 via remove of usrmerge:amd64
Investigating (0) python3:amd64 < 3.11.4-5 -> 3.12.3-0ubuntu2 @ii umU Ib >
Broken python3:amd64 Kollidiert mit on python3-distutils:amd64 < 3.11.5-1 @ii mK Ib >
Considering python3-distutils:amd64 -2 as a solution to python3:amd64 932
Added python3-distutils:amd64 to the remove list
MarkDelete python3-distutils:amd64 < 3.11.5-1 @ii mK Ib > FU=0
Fixing python3:amd64 via remove of python3-distutils:amd64
Investigating (0) libsvtav1enc1d1:amd64 < none -> 1.7.0+dfsg-2build1 @un uN Ib >
Broken libsvtav1enc1d1:amd64 Beschädigt on libsvtav1enc1:amd64 < 1.6.0+dfsg-1 @ii mK > (< 1.6.0+dfsg-2~)
Considering libsvtav1enc1:amd64 -3 as a solution to libsvtav1enc1d1:amd64 31
Added libsvtav1enc1:amd64 to the remove list
Broken libsvtav1enc1d1:amd64 Beschädigt on libsvtav1enc1:i386 < 1.6.0+dfsg-1 @ii mK > (< 1.6.0+dfsg-2~)
Considering libsvtav1enc1:i386 -4 as a solution to libsvtav1enc1d1:amd64 31
Added libsvtav1enc1:i386 to the remove list
MarkDelete libsvtav1enc1:amd64 < 1.6.0+dfsg-1 @ii mK > FU=0
Fixing libsvtav1enc1d1:amd64 via remove of libsvtav1enc1:amd64
MarkDelete libsvtav1enc1:i386 < 1.6.0+dfsg-1 @ii mK > FU=0
Fixing libsvtav1enc1d1:amd64 via remove of libsvtav1enc1:i386
Investigating (0) php-common:amd64 < 2:93ubuntu1 -> 2:93ubuntu2 @ii umU Ib >
Broken php-common:amd64 Beschädigt on php8.2-common:amd64 < 8.2.10-2ubuntu2.2 @ii mK >
Considering php8.2-common:amd64 3 as a solution to php-common:amd64 18
Added php8.2-common:amd64 to the remove list
MarkDelete php8.2-common:amd64 < 8.2.10-2ubuntu2.2 @ii mK > FU=0
Fixing php-common:amd64 via remove of php8.2-common:amd64
Investigating (0) libtss2-mu-4.0.1-0t64:amd64 < none -> 4.0.1-7.1ubuntu5.1 @un umN Ib >
Broken libtss2-mu-4.0.1-0t64:amd64 Kollidiert mit on libtss2-mu0:amd64 < 4.0.1-3ubuntu1.1 @ii mK >
Considering libtss2-mu0:amd64 -3 as a solution to libtss2-mu-4.0.1-0t64:amd64 14
Added libtss2-mu0:amd64 to the remove list
MarkDelete libtss2-mu0:amd64 < 4.0.1-3ubuntu1.1 @ii mK > FU=0
Fixing libtss2-mu-4.0.1-0t64:amd64 via remove of libtss2-mu0:amd64
Investigating (0) libgeos-c1t64:amd64 < none -> 3.12.1-3build1 @un umN Ib >
Broken libgeos-c1t64:amd64 Hängt ab von on libgeos3.12.1t64:amd64 < none | 3.12.1-3build1 @un umH > (>= 3.12.1)
Considering libgeos3.12.1t64:amd64 0 as a solution to libgeos-c1t64:amd64 3
MarkKeep libgeos-c1t64:amd64 < none -> 3.12.1-3build1 @un umN Ib > FU=0
Holding Back libgeos-c1t64:amd64 rather than change libgeos3.12.1t64:amd64
Investigating (0) libgdal34t64:amd64 < none -> 3.8.4+dfsg-3ubuntu3 @un umN Ib >
Broken libgdal34t64:amd64 Hängt ab von on libgeos-c1t64:amd64 < none | 3.12.1-3build1 @un umH > (>= 3.11.0)
Considering libgeos-c1t64:amd64 3 as a solution to libgdal34t64:amd64 2
MarkKeep libgdal34t64:amd64 < none -> 3.8.4+dfsg-3ubuntu3 @un umN Ib > FU=0
Holding Back libgdal34t64:amd64 rather than change libgeos-c1t64:amd64
Investigating (0) libportsmf0t64:amd64 < none -> 0.1~svn20101010-7build1 @un uN Ib >
Broken libportsmf0t64:amd64 Beschädigt on libportsmf0v5:amd64 < 0.1~svn20101010-6ubuntu1 @ii mK Ib > (< 0.1~svn20101010-7build1)
Considering libportsmf0v5:amd64 -3 as a solution to libportsmf0t64:amd64 2
Added libportsmf0v5:amd64 to the remove list
MarkDelete libportsmf0v5:amd64 < 0.1~svn20101010-6ubuntu1 @ii mK Ib > FU=0
Fixing libportsmf0t64:amd64 via remove of libportsmf0v5:amd64
Investigating (0) libopencv-imgcodecs406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib >
Broken libopencv-imgcodecs406t64:amd64 Hängt ab von on libgdal34t64:amd64 < none | 3.8.4+dfsg-3ubuntu3 @un umH > (>= 2.0.1)
Considering libgdal34t64:amd64 2 as a solution to libopencv-imgcodecs406t64:amd64 2
MarkKeep libopencv-imgcodecs406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib > FU=0
Holding Back libopencv-imgcodecs406t64:amd64 rather than change libgdal34t64:amd64
Investigating (0) libiw30t64:amd64 < none -> 30~pre9-16.1ubuntu2 @un uN Ib >
Broken libiw30t64:amd64 Kollidiert mit on libiw30:amd64 < 30~pre9-13.1ubuntu4 @ii mK > (< 30~pre9-16.1ubuntu2)
Considering libiw30:amd64 -3 as a solution to libiw30t64:amd64 2
Added libiw30:amd64 to the remove list
MarkDelete libiw30:amd64 < 30~pre9-13.1ubuntu4 @ii mK > FU=0
Fixing libiw30t64:amd64 via remove of libiw30:amd64
Investigating (0) libopencv-videoio406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib >
Broken libopencv-videoio406t64:amd64 Hängt ab von on libopencv-imgcodecs406t64:amd64 < none | 4.6.0+dfsg-13.1ubuntu1 @un umH > (>= 4.6.0+dfsg)
Considering libopencv-imgcodecs406t64:amd64 2 as a solution to libopencv-videoio406t64:amd64 2
MarkKeep libopencv-videoio406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib > FU=0
Holding Back libopencv-videoio406t64:amd64 rather than change libopencv-imgcodecs406t64:amd64
Investigating (0) libsnmp40t64:i386 < none -> 5.9.4+dfsg-1.1ubuntu3 @un umN Ib >
Broken libsnmp40t64:i386 Hängt ab von on libperl5.38t64:i386 < none | 5.38.2-3.2build2 @un umH > (>= 5.38.2)
Considering libperl5.38t64:i386 0 as a solution to libsnmp40t64:i386 1
MarkKeep libsnmp40t64:i386 < none -> 5.9.4+dfsg-1.1ubuntu3 @un umN Ib > FU=0
Holding Back libsnmp40t64:i386 rather than change libperl5.38t64:i386
Investigating (0) librttopo1:amd64 < 1.1.0-3 -> 1.1.0-3build2 @ii umU Ib >
Broken librttopo1:amd64 Hängt ab von on libgeos-c1t64:amd64 < none | 3.12.1-3build1 @un umH > (>= 3.5.0)
Considering libgeos-c1t64:amd64 3 as a solution to librttopo1:amd64 1
MarkKeep librttopo1:amd64 < 1.1.0-3 -> 1.1.0-3build2 @ii umU Ib > FU=0
Removing librttopo1:amd64 rather than change libgeos-c1t64:amd64
MarkDelete librttopo1:amd64 < 1.1.0-3 | 1.1.0-3build2 @ii umH Ib > FU=0
Investigating (0) libsane1:i386 < 1.2.1-5 -> 1.2.1-7build4 @ii umU NPb Ib >
Broken libsane1:i386 Hängt ab von on libsnmp40t64:i386 < none | 5.9.4+dfsg-1.1ubuntu3 @un umH > (>= 5.9.4+dfsg)
Considering libsnmp40t64:i386 1 as a solution to libsane1:i386 1
MarkKeep libsane1:i386 < 1.2.1-5 -> 1.2.1-7build4 @ii umU NPb Ib > FU=0
Removing libsane1:i386 rather than change libsnmp40t64:i386
MarkDelete libsane1:i386 < 1.2.1-5 | 1.2.1-7build4 @ii umH NPb Ib > FU=0
Investigating (0) libpoppler-glib8t64:i386 < none -> 24.02.0-1ubuntu9.1 @un umN Ib >
Broken libpoppler-glib8t64:i386 Hängt ab von on libpoppler134:i386 < none | 24.02.0-1ubuntu9.1 @un umH > (= 24.02.0-1ubuntu9.1)
Considering libpoppler134:i386 0 as a solution to libpoppler-glib8t64:i386 1
MarkKeep libpoppler-glib8t64:i386 < none -> 24.02.0-1ubuntu9.1 @un umN Ib > FU=0
Holding Back libpoppler-glib8t64:i386 rather than change libpoppler134:i386
Investigating (0) libspatialite8t64:amd64 < none -> 5.1.0-3build1 @un umN Ib >
Broken libspatialite8t64:amd64 Hängt ab von on libgeos-c1t64:amd64 < none | 3.12.1-3build1 @un umH > (>= 3.11.0)
Considering libgeos-c1t64:amd64 3 as a solution to libspatialite8t64:amd64 0
MarkKeep libspatialite8t64:amd64 < none -> 5.1.0-3build1 @un umN Ib > FU=0
Holding Back libspatialite8t64:amd64 rather than change libgeos-c1t64:amd64
Investigating (0) libopencv-highgui406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib >
Broken libopencv-highgui406t64:amd64 Hängt ab von on libopencv-imgcodecs406t64:amd64 < none | 4.6.0+dfsg-13.1ubuntu1 @un umH > (>= 4.6.0+dfsg)
Considering libopencv-imgcodecs406t64:amd64 2 as a solution to libopencv-highgui406t64:amd64 0
MarkKeep libopencv-highgui406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib > FU=0
Holding Back libopencv-highgui406t64:amd64 rather than change libopencv-imgcodecs406t64:amd64
Investigating (0) php8.2-opcache:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib >
Broken php8.2-opcache:amd64 Hängt ab von on php8.2-common:amd64 < 8.2.10-2ubuntu2.2 @ii mR > (= 8.2.10-2ubuntu2.2)
Considering php8.2-common:amd64 3 as a solution to php8.2-opcache:amd64 0
Removing php8.2-opcache:amd64 rather than change php8.2-common:amd64
MarkDelete php8.2-opcache:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib > FU=0
Investigating (0) php8.2-cli:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib >
Broken php8.2-cli:amd64 Hängt ab von on php8.2-common:amd64 < 8.2.10-2ubuntu2.2 @ii mR > (= 8.2.10-2ubuntu2.2)
Considering php8.2-common:amd64 3 as a solution to php8.2-cli:amd64 -1
Removing php8.2-cli:amd64 rather than change php8.2-common:amd64
MarkDelete php8.2-cli:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib > FU=0
Investigating (0) php8.2-readline:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib >
Broken php8.2-readline:amd64 Hängt ab von on php8.2-common:amd64 < 8.2.10-2ubuntu2.2 @ii mR > (= 8.2.10-2ubuntu2.2)
Considering php8.2-common:amd64 3 as a solution to php8.2-readline:amd64 -1
Removing php8.2-readline:amd64 rather than change php8.2-common:amd64
MarkDelete php8.2-readline:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib > FU=0
Investigating (0) libapache2-mod-php8.2:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib >
Broken libapache2-mod-php8.2:amd64 Hängt ab von on php8.2-cli:amd64 < 8.2.10-2ubuntu2.2 @ii mR >
Considering php8.2-cli:amd64 -1 as a solution to libapache2-mod-php8.2:amd64 -1
Removing libapache2-mod-php8.2:amd64 rather than change php8.2-cli:amd64
MarkDelete libapache2-mod-php8.2:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib > FU=0
Investigating (0) php8.2-mysql:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib >
Broken php8.2-mysql:amd64 Hängt ab von on php8.2-common:amd64 < 8.2.10-2ubuntu2.2 @ii mR > (= 8.2.10-2ubuntu2.2)
Considering php8.2-common:amd64 3 as a solution to php8.2-mysql:amd64 -2
Removing php8.2-mysql:amd64 rather than change php8.2-common:amd64
MarkDelete php8.2-mysql:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib > FU=0
Investigating (0) php8.2:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib >
Broken php8.2:amd64 Hängt ab von on libapache2-mod-php8.2:amd64 < 8.2.10-2ubuntu2.2 @ii mR >
Considering libapache2-mod-php8.2:amd64 -1 as a solution to php8.2:amd64 -2
Broken php8.2:amd64 Hängt ab von on php8.2-fpm:amd64 < none @un mH >
Broken php8.2:amd64 Hängt ab von on php8.2-cgi:amd64 < none @un mH >
Or group remove for php8.2:amd64
MarkDelete php8.2:amd64 < 8.2.10-2ubuntu2.2 @ii mK Ib > FU=0
Broken php8.2:amd64 Hängt ab von on php8.2-common:amd64 < 8.2.10-2ubuntu2.2 @ii mR >
Considering php8.2-common:amd64 3 as a solution to php8.2:amd64 -2
MarkKeep php8.2:amd64 < 8.2.10-2ubuntu2.2 @ii mR > FU=0
Removing php8.2:amd64 rather than change php8.2-common:amd64
Investigating (0) libgdal33:amd64 < 3.7.1+dfsg-1build1 @ii mK Ib >
Broken libgdal33:amd64 Hängt ab von on libgeos-c1v5:amd64 < 3.12.0-1 @ii pmR > (>= 3.11.0~beta1)
Considering libgeos-c1v5:amd64 0 as a solution to libgdal33:amd64 -2
Removing libgdal33:amd64 rather than change libgeos-c1v5:amd64
MarkDelete libgdal33:amd64 < 3.7.1+dfsg-1build1 @ii mK Ib > FU=0
Investigating (0) wine-devel-i386:i386 < 9.9~jammy-1 @ii mK Ib >
Broken wine-devel-i386:i386 Hängt ab von on libsane1:i386 < 1.2.1-5 | 1.2.1-7build4 @ii umR NPb > (>= 1.0.27)
Considering libsane1:i386 1 as a solution to wine-devel-i386:i386 -2
Removing wine-devel-i386:i386 rather than change libsane1:i386
MarkDelete wine-devel-i386:i386 < 9.9~jammy-1 @ii mK Ib > FU=0
Investigating (0) libavif15:amd64 < 0.11.1-3ubuntu1 @ii mK Ib >
Broken libavif15:amd64 Hängt ab von on libsvtav1enc1:amd64 < 1.6.0+dfsg-1 @ii mR > (>= 1.6.0+dfsg)
Considering libsvtav1enc1:amd64 -3 as a solution to libavif15:amd64 -2
MarkKeep libsvtav1enc1:amd64 < 1.6.0+dfsg-1 @ii mR > FU=0
Fixing libavif15:amd64 via keep of libsvtav1enc1:amd64
Investigating (0) python3.11-venv:amd64 < 3.11.6-3ubuntu0.1 @ii mK Ib >
Broken python3.11-venv:amd64 Hängt ab von on python3.11-distutils:amd64 < none @un mH >
Considering python3-distutils:amd64 -2 as a solution to python3.11-venv:amd64 -2
Removing python3.11-venv:amd64 rather than change python3.11-distutils:amd64
MarkDelete python3.11-venv:amd64 < 3.11.6-3ubuntu0.1 @ii mK Ib > FU=0
Investigating (1) libsvtav1enc1d1:amd64 < none -> 1.7.0+dfsg-2build1 @un uN Ib >
Investigating (1) libopencv-contrib406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib >
Broken libopencv-contrib406t64:amd64 Hängt ab von on libopencv-highgui406t64:amd64 < none | 4.6.0+dfsg-13.1ubuntu1 @un umH > (>= 4.6.0+dfsg)
Considering libopencv-highgui406t64:amd64 0 as a solution to libopencv-contrib406t64:amd64 3
MarkKeep libopencv-contrib406t64:amd64 < none -> 4.6.0+dfsg-13.1ubuntu1 @un umN Ib > FU=0
Holding Back libopencv-contrib406t64:amd64 rather than change libopencv-highgui406t64:amd64
Investigating (1) libopenscenegraph161:amd64 < 3.6.5+dfsg1-8build3 -> 3.6.5+dfsg1-8build10 @ii umU Ib >
Broken libopenscenegraph161:amd64 Hängt ab von on libgdal34:amd64 < none @un H > (>= 3.0.0)
Considering libgdal34t64:amd64 2 as a solution to libopenscenegraph161:amd64 2
MarkKeep libopenscenegraph161:amd64 < 3.6.5+dfsg1-8build3 -> 3.6.5+dfsg1-8build10 @ii umU Ib > FU=0
Removing libopenscenegraph161:amd64 rather than change libgdal34:amd64
MarkDelete libopenscenegraph161:amd64 < 3.6.5+dfsg1-8build3 | 3.6.5+dfsg1-8build10 @ii umH Ib > FU=0
Investigating (1) libgmic1:amd64 < 2.9.4-4build4 -> 2.9.4-4build11 @ii umU Ib >
Broken libgmic1:amd64 Hängt ab von on libopencv-videoio406t64:amd64 < none | 4.6.0+dfsg-13.1ubuntu1 @un umH > (>= 4.6.0+dfsg)
Considering libopencv-videoio406t64:amd64 2 as a solution to libgmic1:amd64 2
MarkKeep libgmic1:amd64 < 2.9.4-4build4 -> 2.9.4-4build11 @ii umU Ib > FU=0
Removing libgmic1:amd64 rather than change libopencv-videoio406t64:amd64
MarkDelete libgmic1:amd64 < 2.9.4-4build4 | 2.9.4-4build11 @ii umH Ib > FU=0
Investigating (1) scribus:amd64 < 1.5.8+dfsg-4build4 -> 1.6.1-0ubuntu7 @ii umU Ib >
Broken scribus:amd64 Hängt ab von on libopenscenegraph161:amd64 < 3.6.5+dfsg1-8build3 | 3.6.5+dfsg1-8build10 @ii umR > (>= 3.6.5+dfsg1)
Considering libopenscenegraph161:amd64 2 as a solution to scribus:amd64 1
MarkKeep scribus:amd64 < 1.5.8+dfsg-4build4 -> 1.6.1-0ubuntu7 @ii umU Ib > FU=0
Removing scribus:amd64 rather than change libopenscenegraph161:amd64
MarkDelete scribus:amd64 < 1.5.8+dfsg-4build4 | 1.6.1-0ubuntu7 @ii umH Ib > FU=0
Investigating (1) gmic:amd64 < 2.9.4-4build4 -> 2.9.4-4build11 @ii umU Ib >
Broken gmic:amd64 Hängt ab von on libgmic1:amd64 < 2.9.4-4build4 | 2.9.4-4build11 @ii umR > (= 2.9.4-4build11)
Considering libgmic1:amd64 2 as a solution to gmic:amd64 0
MarkKeep gmic:amd64 < 2.9.4-4build4 -> 2.9.4-4build11 @ii umU Ib > FU=0
Removing gmic:amd64 rather than change libgmic1:amd64
MarkDelete gmic:amd64 < 2.9.4-4build4 | 2.9.4-4build11 @ii umH Ib > FU=0
Investigating (1) gimp-gmic:amd64 < 2.9.4-4build4 -> 2.9.4-4build11 @ii umU Ib >
Broken gimp-gmic:amd64 Hängt ab von on libgmic1:amd64 < 2.9.4-4build4 | 2.9.4-4build11 @ii umR > (= 2.9.4-4build11)
Considering libgmic1:amd64 2 as a solution to gimp-gmic:amd64 0
MarkKeep gimp-gmic:amd64 < 2.9.4-4build4 -> 2.9.4-4build11 @ii umU Ib > FU=0
Removing gimp-gmic:amd64 rather than change libgmic1:amd64
MarkDelete gimp-gmic:amd64 < 2.9.4-4build4 | 2.9.4-4build11 @ii umH Ib > FU=0
Investigating (1) wine-devel:amd64 < 9.9~jammy-1 @ii mK Ib >
Broken wine-devel:amd64 Hängt ab von on wine-devel-i386:amd64 < none @un mH > (= 9.9~jammy-1)
Considering wine-devel-i386:i386 -2 as a solution to wine-devel:amd64 -1
Added wine-devel-i386:i386 to the remove list
MarkKeep wine-devel-i386:i386 < 9.9~jammy-1 @ii mR > FU=0
Fixing wine-devel:amd64 via keep of wine-devel-i386:i386
Investigating (1) wine-devel-i386:i386 < 9.9~jammy-1 @ii mK Ib >
Investigating (1) libavif15:amd64 < 0.11.1-3ubuntu1 @ii mK Ib >
Investigating (2) libsvtav1enc1d1:amd64 < none -> 1.7.0+dfsg-2build1 @un uN Ib >
Investigating (2) libmlt7:amd64 < 7.18.0-1 -> 7.22.0-1build6 @ii umU Ib >
Broken libmlt7:amd64 Hängt ab von on libopencv-contrib406t64:amd64 < none | 4.6.0+dfsg-13.1ubuntu1 @un umH > (>= 4.6.0+dfsg)
Considering libopencv-contrib406t64:amd64 3 as a solution to libmlt7:amd64 8
MarkKeep libmlt7:amd64 < 7.18.0-1 -> 7.22.0-1build6 @ii umU Ib > FU=0
Removing libmlt7:amd64 rather than change libopencv-contrib406t64:amd64
MarkDelete libmlt7:amd64 < 7.18.0-1 | 7.22.0-1build6 @ii umH Ib > FU=0
Investigating (2) libmlt++7:amd64 < 7.18.0-1 -> 7.22.0-1build6 @ii umU Ib >
Broken libmlt++7:amd64 Hängt ab von on libmlt7:amd64 < 7.18.0-1 | 7.22.0-1build6 @ii umR > (>= 7.22.0)
Considering libmlt7:amd64 8 as a solution to libmlt++7:amd64 7
MarkKeep libmlt++7:amd64 < 7.18.0-1 -> 7.22.0-1build6 @ii umU Ib > FU=0
Removing libmlt++7:amd64 rather than change libmlt7:amd64
MarkDelete libmlt++7:amd64 < 7.18.0-1 | 7.22.0-1build6 @ii umH Ib > FU=0
Investigating (2) kdenlive:amd64 < 4:23.08.1-0ubuntu1 -> 4:23.08.5-0ubuntu4 @ii umU Ib >
Broken kdenlive:amd64 Hängt ab von on libmlt++7:amd64 < 7.18.0-1 | 7.22.0-1build6 @ii umR > (>= 7.22.0)
Considering libmlt++7:amd64 8 as a solution to kdenlive:amd64 3
MarkKeep kdenlive:amd64 < 4:23.08.1-0ubuntu1 -> 4:23.08.5-0ubuntu4 @ii umU Ib > FU=0
Removing kdenlive:amd64 rather than change libmlt++7:amd64
MarkDelete kdenlive:amd64 < 4:23.08.1-0ubuntu1 | 4:23.08.5-0ubuntu4 @ii umH Ib > FU=0
Investigating (2) melt:amd64 < 7.18.0-1 -> 7.22.0-1build6 @ii umU Ib >
Broken melt:amd64 Hängt ab von on libmlt7:amd64 < 7.18.0-1 | 7.22.0-1build6 @ii umR > (>= 7.22.0)
Considering libmlt7:amd64 8 as a solution to melt:amd64 3
MarkKeep melt:amd64 < 7.18.0-1 -> 7.22.0-1build6 @ii umU Ib > FU=0
Removing melt:amd64 rather than change libmlt7:amd64
MarkDelete melt:amd64 < 7.18.0-1 | 7.22.0-1build6 @ii umH Ib > FU=0
Investigating (2) wine-devel:amd64 < 9.9~jammy-1 @ii mK Ib >
Investigating (2) wine-devel-i386:i386 < 9.9~jammy-1 @ii mK Ib >
Considering libsane1:i386 1 as a solution to wine-devel-i386:i386 -1
Investigating (2) libavif15:amd64 < 0.11.1-3ubuntu1 @ii mK Ib >
Considering libsvtav1enc1:amd64 31 as a solution to libavif15:amd64 -2
Removing libavif15:amd64 rather than change libsvtav1enc1:amd64
MarkDelete libavif15:amd64 < 0.11.1-3ubuntu1 @ii mK Ib > FU=0
Investigating (3) wine-devel:amd64 < 9.9~jammy-1 @ii mK Ib >
Considering wine-devel-i386:i386 1 as a solution to wine-devel:amd64 -1
Removing wine-devel:amd64 rather than change wine-devel-i386:amd64
MarkDelete wine-devel:amd64 < 9.9~jammy-1 @ii mK Ib > FU=0
Investigating (3) wine-devel-dev:amd64 < 9.9~jammy-1 @ii mK Ib >
Broken wine-devel-dev:amd64 Hängt ab von on wine-devel-i386:amd64 < none @un mH > (= 9.9~jammy-1)
Considering wine-devel-i386:i386 1 as a solution to wine-devel-dev:amd64 -2
Removing wine-devel-dev:amd64 rather than change wine-devel-i386:amd64
MarkDelete wine-devel-dev:amd64 < 9.9~jammy-1 @ii mK Ib > FU=0
Investigating (4) winehq-devel:amd64 < 9.9~jammy-1 @ii mK Ib >
Broken winehq-devel:amd64 Hängt ab von on wine-devel:amd64 < 9.9~jammy-1 @ii mR > (= 9.9~jammy-1)
Considering wine-devel:amd64 1 as a solution to winehq-devel:amd64 0
Removing winehq-devel:amd64 rather than change wine-devel:amd64
MarkDelete winehq-devel:amd64 < 9.9~jammy-1 @ii mK Ib > FU=0
Investigating (4) winetricks:amd64 < 20230212-2 -> 20240105-2 @ii umU Ib >
Broken winetricks:amd64 Hängt ab von on wine:amd64 < none | 9.0~repack-4build3 @un umH >
Considering wine:amd64 1 as a solution to winetricks:amd64 0
MarkKeep winetricks:amd64 < 20230212-2 -> 20240105-2 @ii umU Ib > FU=0
Removing winetricks:amd64 rather than change wine:amd64
MarkDelete winetricks:amd64 < 20230212-2 | 20240105-2 @ii umH Ib > FU=0
Investigating (5) carla-bridge-wine64:amd64 < 2.5.7-0ubuntu1 -> 2.5.8-0ubuntu5 @ii umU Ib >
Broken carla-bridge-wine64:amd64 Hängt ab von on wine-development:amd64 < none @un mH >
Broken carla-bridge-wine64:amd64 Hängt ab von on wine-staging:amd64 < none @un mH >
Broken carla-bridge-wine64:amd64 Hängt ab von on wine-stable:amd64 < none | 3.0.1ubuntu1 @un umH >
Considering wine-stable:amd64 1 as a solution to carla-bridge-wine64:amd64 2
MarkKeep carla-bridge-wine64:amd64 < 2.5.7-0ubuntu1 -> 2.5.8-0ubuntu5 @ii umU Ib > FU=0
Try Installing wine-stable:amd64 < none | 3.0.1ubuntu1 @un umH > before changing carla-bridge-wine64:amd64
MarkInstall wine-stable:amd64 < none -> 3.0.1ubuntu1 @un umN Ib > FU=0
Installing winehq-devel:amd64 as Hängt ab von of wine-stable:amd64
MarkKeep winehq-devel:amd64 < 9.9~jammy-1 @ii mR > FU=0
Investigating (5) winehq-devel:amd64 < 9.9~jammy-1 @ii mK Ib >
Considering wine-devel:amd64 1 as a solution to winehq-devel:amd64 1
Try to Re-Instate (6) carla-bridge-wine64:amd64
Re-Instated carla-bridge-wine64:amd64 (1 vs 1)
Investigating (6) wine-stable:amd64 < none -> 3.0.1ubuntu1 @un umN Ib >
Broken wine-stable:amd64 Hängt ab von on wine:amd64 < none | 9.0~repack-4build3 @un umH >
Considering wine:amd64 1 as a solution to wine-stable:amd64 1
MarkKeep wine-stable:amd64 < none -> 3.0.1ubuntu1 @un umN Ib > FU=0
Holding Back wine-stable:amd64 rather than change wine:amd64
Investigating (7) carla-bridge-wine64:amd64 < 2.5.7-0ubuntu1 -> 2.5.8-0ubuntu5 @ii umU Ib >
Investigating (7) winehq-devel:amd64 < 9.9~jammy-1 @ii mK Ib >
Investigating (8) wine-stable:amd64 < none -> 3.0.1ubuntu1 @un umN Ib >
Investigating (9) carla-bridge-wine64:amd64 < 2.5.7-0ubuntu1 | 2.5.8-0ubuntu5 @ii umH Ib >
Investigating (9) winehq-devel:amd64 < 9.9~jammy-1 @ii mK Ib >
So as I couldn't find a hint what's the problem (seems something with the dependencies) It could be time for a fresh install?
Thanks for helping.
