So, I want to bind two different keyboard keys to the system mute function. I go to system settings > keyboard > shortcuts > sound and media and find the Volume Mute setting and enter the second shortcut I want for it. However, this deletes the first shortcut. How can I bind two keys to this function?
Jorge Castro
  • 73,717
It is quite easy to do such a thing if you know the command for doing that function.
If you are using ALSA sound driver, the commands are :
amixer set Master mute` for muting the system
    "amixer set Master unmute" for unmuting the system
    "amixer set Master toggle" for toggling volume.
    "amixer set Master <vol>" to set volume level to <vol>
So, in the Keyboard shortcut option, click on Add and in the Command box, enter the functionality that you want.
Hope this helps.
Five
  • 301
