I saw some tutorials that claims zalo can be installed through wine on ubuntu but none of them have posted welcome or login screen of the application. Normally we do not see fake answers on askubuntu so i decided to follow this guide and i realized it is fake Cannot install Windows application through Wine on Ubuntu 22.04 (@daniel-t)
I tried to install this app on Ubuntu 24.04.1 LTS (Noble Numbat) and Ubuntu 24.10 (Oracular Oriole)
(a) Ubuntu 24.04.1 LTS (Noble Numbat)
sudo apt install wine wgetwget https://res-download-pc-te-vnso-tt-2.zadn.vn/win/ZaloSetup-24.8.5.exe(downloaded the latest version)- Run
wine ZaloSetup-24.8.5.exe.
Advice-1: If you got error message, "it looks like wine32 is missing, you should install it. multiarch needs to be enabled first". Please execute sudo dpkg --add-architecture i386, sudo apt-get update, sudo apt install wine32
Advice-2: During installation, If you got error message in the terminal; "no NTLM support, expect problems. ntlm_auth was not found. Usually, you can find it in the winbind package of your distribution". Please execute sudo apt install winbind
After the installation wizard appeared, i can choose a language and complete the installation.
zalo-setup-language-screenshot zalo-installing-screenshot
wine: created the configuration directory '/home/store/.wine'
0054:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
0054:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
0054:err:ole:apartment_get_local_server_stream Failed: 0x80004002
0054:err:ole:start_rpcss Failed to open RpcSs service
004c:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
004c:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
004c:err:ole:apartment_get_local_server_stream Failed: 0x80004002
wine: configuration in L"/home/store/.wine" has been updated.
0134:err:wininet:open_http_connection create_netconn failed: 12029
0138:err:wininet:open_http_connection create_netconn failed: 12029
0178:err:wininet:open_http_connection create_netconn failed: 12029
017c:err:wininet:open_http_connection create_netconn failed: 12029
0180:err:wininet:open_http_connection create_netconn failed: 12029
0194:err:ole:create_server class {9ba05972-f6a8-11cf-a442-00a0c90a8f39} not registered
0194:err:ole:com_get_class_object no class object {9ba05972-f6a8-11cf-a442-00a0c90a8f39} could be created for context 0x4
When Zalo application launches automatically. At this stage it fails and the wine debugger appears with an error message. "the program zalo.exe has encountered a serious problem and needs to close. We are sorry for the inconveniences".
0260:err:ole:com_get_class_object class {7ab36653-1796-484b-bdfa-e74f1db7c1dc} not registered
0260:err:ole:create_server class {7ab36653-1796-484b-bdfa-e74f1db7c1dc} not registered
0260:err:ole:com_get_class_object no class object {7ab36653-1796-484b-bdfa-e74f1db7c1dc} could be created for context 0x5
01d4:err:ole:com_get_class_object class {aa509086-5ca9-4c25-8f95-589d3c07b48a} not registered
01d4:err:ole:create_server class {aa509086-5ca9-4c25-8f95-589d3c07b48a} not registered
01d4:err:ole:com_get_class_object no class object {aa509086-5ca9-4c25-8f95-589d3c07b48a} could be created for context 0x17
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 21010059.
03b4:err:d3d:wined3d_context_gl_update_window Failed to get a device context for window 0907A688.
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 04010060.
03b4:err:d3d:wined3d_context_gl_update_window Failed to get a device context for window 0907B210.
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 05010065.
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 05010069.
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 0501006E.
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 05010072.
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 05010077.
wine: Unhandled exception 0x80000003 in thread 360 at address 0579B2CF (thread 0360), starting debugger...
03b4:err:d3d:wined3d_context_gl_set_pixel_format wglSetPixelFormatWINE failed to set pixel format 1 on device context 0601007B.
This is the backtrace
0x0579b2cf zalo+0x539b2cf: int3
Modules:
Module Address Debug info Name (119 modules)
PE 400000- 89d6000 Export zalo
ELF 5d0cd000-5d0d2000 Deferred <wine-loader>
PE-Wine 71e70000-720b6000 Deferred gdiplus
PE 720d0000-7210e000 Deferred file-utils.node
PE-Wine 76f50000-76f71000 Deferred powrprof
PE-Wine 76f90000-77010000 Deferred netapi32
PE-Wine 77020000-7705b000 Deferred msv1_0
PE-Wine 77070000-77099000 Deferred kerberos
PE-Wine 770b0000-77155000 Deferred uxtheme
PE-Wine 77170000-771bc000 Deferred winex11
PE-Wine 771d0000-771ec000 Deferred dhcpcsvc
PE-Wine 77200000-77241000 Deferred jsproxy
PE-Wine 77260000-77361000 Deferred winhttp
PE-Wine 77380000-77413000 Deferred secur32
PE-Wine 77430000-778d7000 Deferred comctl32
PE-Wine 778f0000-77914000 Deferred compstui
PE-Wine 77930000-779d0000 Deferred winspool
PE-Wine 779e0000-77c6d000 Deferred dwrite
PE-Wine 77c80000-77ca6000 Deferred userenv
PE-Wine 77cc0000-77cdb000 Deferred version
PE-Wine 77cf0000-77d0e000 Deferred nsi
PE-Wine 77d20000-77d60000 Deferred dnsapi
PE-Wine 77d70000-77de8000 Deferred iphlpapi
PE-Wine 77e00000-77e47000 Deferred bcrypt
PE-Wine 77e60000-7815b000 Deferred crypt32
PE-Wine 78170000-781fb000 Deferred ws2_32
PE-Wine 78210000-78276000 Deferred msacm32
PE-Wine 78290000-78402000 Deferred winmm
PE-Wine 78420000-78435000 Deferred msimg32
PE-Wine 78450000-786aa000 Deferred dbghelp
PE-Wine 786c0000-78a7c000 Deferred oleaut32
PE-Wine 78a90000-78b4c000 Deferred oleacc
PE-Wine 78b60000-78ba1000 Deferred coml2
PE-Wine 78bc0000-78dd1000 Deferred rpcrt4
PE-Wine 78df0000-78f32000 Deferred combase
PE-Wine 78f50000-7938d000 Deferred ole32
PE-Wine 793a0000-794fb000 Deferred uiautomationcore
PE 79510000-79899000 Deferred ffmpeg
PE-Wine 798b0000-79913000 Deferred imm32
PE-Wine 79930000-79971000 Deferred shcore
PE-Wine 79990000-79a76000 Deferred shlwapi
PE-Wine 79a90000-7a70e000 Deferred shell32
PE-Wine 7a720000-7a757000 Deferred win32u
PE-Wine 7a770000-7a9b0000 Deferred gdi32
PE-Wine 7a9c0000-7accf000 Deferred ucrtbase
PE-Wine 7ace0000-7ad6b000 Deferred sechost
PE-Wine 7ad80000-7ae6c000 Deferred advapi32
PE-Wine 7ae80000-7b119000 Deferred msvcrt
PE-Wine 7b130000-7b15a000 Deferred zlib1
PE-Wine 7b170000-7b637000 Deferred user32
PE-Wine 7b650000-7bb7b000 Dwarf-4 kernelbase
PE-Wine 7bb90000-7bcf7000 Deferred kernel32
PE-Wine 7bd10000-7bfee000 Deferred ntdll
ELF eee4d000-eee52000 Deferred msv1_0.so
ELF eee52000-eee57000 Deferred netapi32.so
ELF eee57000-eee82000 Deferred libgpg-error.so.0
ELF eee82000-eef3f000 Deferred libzstd.so.1
ELF eef3f000-eef75000 Deferred liblzma.so.5
ELF eef75000-eef9b000 Deferred liblz4.so.1
ELF eef9b000-ef0a8000 Deferred libgcrypt.so.20
ELF ef0a8000-ef0b5000 Deferred libcap.so.2
ELF ef0b5000-ef19c000 Deferred libsystemd.so.0
ELF ef19c000-ef1ae000 Deferred libresolv.so.2
ELF ef1ae000-ef20e000 Deferred libdbus-1.so.3
ELF ef20e000-ef21d000 Deferred libkrb5support.so.0
ELF ef21d000-ef24d000 Deferred libk5crypto.so.3
ELF ef24d000-ef329000 Deferred libkrb5.so.3
ELF ef329000-ef33f000 Deferred libavahi-client.so.3
ELF ef33f000-ef34e000 Deferred libavahi-common.so.3
ELF ef34e000-ef3a9000 Deferred libgssapi_krb5.so.2
ELF ef3a9000-ef455000 Deferred libcups.so.2
ELF ef456000-ef45e000 Deferred kerberos.so
ELF ef45e000-ef468000 Deferred secur32.so
ELF ef54f000-ef557000 Deferred libxfixes.so.3
ELF ef557000-ef564000 Deferred libxcursor.so.1
ELF ef564000-ef579000 Deferred libxi.so.6
ELF ef579000-ef57e000 Deferred libxcomposite.so.1
ELF ef57e000-ef58d000 Deferred libxrandr.so.2
ELF ef58d000-ef59b000 Deferred libxrender.so.1
ELF ef59b000-ef5a3000 Deferred libxxf86vm.so.1
ELF ef5a3000-ef5a8000 Deferred libxinerama.so.1
ELF ef5a8000-ef5ba000 Deferred libmd.so.0
ELF ef5ba000-ef5d0000 Deferred libbsd.so.0
ELF ef5d0000-ef5d7000 Deferred libxdmcp.so.6
ELF ef5d7000-ef5dc000 Deferred libxau.so.6
ELF ef5dc000-ef60a000 Deferred libxcb.so.1
ELF ef60a000-ef75c000 Deferred libx11.so.6
ELF ef75c000-ef772000 Deferred libxext.so.6
ELF ef773000-ef77a000 Deferred libkeyutils.so.1
ELF ef77a000-ef77f000 Deferred libcom_err.so.2
ELF ef77f000-ef785000 Deferred winspool.so
ELF ef785000-ef80f000 Deferred winex11.so
ELF ef80f000-ef81a000 Deferred libffi.so.8
ELF ef81a000-ef8ab000 Deferred libgmp.so.10
ELF ef8ab000-ef8f4000 Deferred libhogweed.so.6
ELF ef8f4000-ef947000 Deferred libnettle.so.8
ELF ef947000-ef95e000 Deferred libtasn1.so.6
ELF ef95e000-efb0b000 Deferred libunistring.so.5
ELF efb0b000-efb3f000 Deferred libidn2.so.0
ELF efb3f000-efd0d000 Deferred libp11-kit.so.0
ELF efd0d000-eff4e000 Deferred libgnutls.so.30
ELF eff50000-eff56000 Deferred dwrite.so
ELF eff56000-eff5b000 Deferred dnsapi.so
ELF eff5b000-eff61000 Deferred crypt32.so
ELF eff61000-eff6e000 Deferred bcrypt.so
ELF eff6e000-eff74000 Deferred ws2_32.so
ELF f0037000-f0063000 Deferred libexpat.so.1
ELF f0063000-f00b7000 Deferred libfontconfig.so.1
ELF f00b7000-f00da000 Deferred libbrotlicommon.so.1
ELF f00da000-f0117000 Deferred libpng16.so.16
ELF f0117000-f0129000 Deferred libbz2.so.1.0
ELF f0129000-f0145000 Deferred libz.so.1
ELF f0145000-f0219000 Deferred libfreetype.so.6
ELF f0219000-f0323000 Deferred libm.so.6
ELF f0336000-f04b9000 Deferred win32u.so
ELF f04b9000-f056e000 Export ntdll.so
ELF f056e000-f07aa000 Deferred libc.so.6
ELF f07ad000-f07bb000 Deferred libbrotlidec.so.1
ELF f07c5000-f07fa000 Deferred ld-linux.so.2
Threads:
process tid prio name (all IDs are in hex)
00000030 services.exe
00000034 0
00000038 0 wine_rpcrt4_server
0000003c 0
00000070 0 wine_rpcrt4_io
000000b0 0 wine_rpcrt4_io
000000c4 0 wine_rpcrt4_io
000000fc 0 wine_rpcrt4_io
0000011c 0 wine_rpcrt4_io
000001ac 0 wine_rpcrt4_io
00000048 explorer.exe
0000004c 0
00000058 0
00000068 winedevice.exe
0000006c 0
00000078 0
0000007c 0 wine_sechost_service
00000080 0
00000084 0
00000088 0
000000d4 0
000000d8 0
000000a8 svchost.exe
000000ac 0
000000b4 0
000000b8 0 wine_sechost_service
000000bc plugplay.exe
000000c0 0
000000c8 0
000000cc 0 wine_sechost_service
000000d0 0 wine_rpcrt4_server
0000012c 0 wine_rpcrt4_io
00000248 0 wine_rpcrt4_io
0000024c 0 wine_threadpool_worker
000000f4 winedevice.exe
000000f8 0
00000100 0
00000104 0 wine_sechost_service
00000108 0
0000010c 0
00000110 0
00000124 0
00000128 0
000001a4 rpcss.exe
000001a8 0
000001b0 0
000001b4 0 wine_sechost_service
000001b8 0 wine_rpcrt4_server
000001bc 0 wine_rpcrt4_server
00000264 0 wine_rpcrt4_io
000001d0 Zalo.exe
000001d4 0 CrBrowserMain
000001d8 0 BrokerEvent
000001dc 0 ThreadPoolServiceThread
000001e0 0 ThreadPoolForegroundWorker
000001e4 -2 ThreadPoolBackgroundWorker
000001e8 0 ThreadPoolForegroundWorker
000001ec 0 Chrome_IOThread
000001f0 0 MemoryInfra
000001f4 0
000001f8 0
000001fc 0
00000200 0
00000204 0
00000208 0
0000020c 0
00000210 0
00000214 -2 ThreadPoolSingleThreadCOMSTASharedBackgroundBlocking0
00000218 0 wine_threadpool_worker
0000021c 0 wine_threadpool_waitqueue
00000220 0 ThreadPoolSingleThreadCOMSTASharedForeground1
00000224 0 ThreadPoolForegroundWorker
00000228 0 ThreadPoolForegroundWorker
0000022c 0 ThreadPoolSingleThreadForegroundBlocking2
00000230 0 CompositorTileWorker1
0000023c 0 wine_sechost_device_notify
00000240 0 VideoCaptureThread
00000244 0
00000250 0 ThreadPoolSingleThreadSharedForeground3
0000025c 0 ThreadPoolForegroundWorker
00000260 0 ThreadPoolSingleThreadCOMSTASharedForegroundBlocking4
00000268 0 wine_rpcrt4_server
0000026c -2 ThreadPoolBackgroundWorker
00000270 0 ThreadPoolForegroundWorker
00000284 0 CacheThread_BlockFile
000002dc -2 ThreadPoolSingleThreadSharedBackgroundBlocking5
00000464 0 ThreadPoolForegroundWorker
00000468 0 ThreadPoolForegroundWorker
0000046c 0 ThreadPoolForegroundWorker
00000470 0 ThreadPoolForegroundWorker
00000474 0 ThreadPoolForegroundWorker
00000478 0 ThreadPoolForegroundWorker
0000047c 0 ThreadPoolForegroundWorker
00000480 0 ThreadPoolForegroundWorker
00000484 0 ThreadPoolForegroundWorker
00000514 0 wine_wininet_collect_connections
00000234 Zalo.exe
00000238 1 CrGpuMain
00000318 0 GpuWatchdog
000003b4 0 wined3d_cs
000003bc 0 ThreadPoolServiceThread
000003c0 0 ThreadPoolForegroundWorker
000003c4 -2 ThreadPoolBackgroundWorker
000003c8 1 Chrome_ChildIOThread
000003d0 0 wine_threadpool_worker
000003d4 0 wine_threadpool_waitqueue
000003d8 0 ThreadPoolForegroundWorker
000003dc 1 VizCompositorThread
00000454 -2 ThreadPoolBackgroundWorker
000004d0 0 ThreadPoolForegroundWorker
000004d4 0 ThreadPoolForegroundWorker
00000254 Zalo.exe
00000258 0 CrUtilityMain
000002a0 0 BrokerEvent
000002a4 0 ThreadPoolServiceThread
000002a8 0 ThreadPoolForegroundWorker
000002ac -2 ThreadPoolBackgroundWorker
000002b0 0 Chrome_ChildIOThread
000002b4 0 ThreadPoolForegroundWorker
000002b8 0 ThreadPoolForegroundWorker
000002bc 0 wine_threadpool_worker
000002c0 -2 ThreadPoolSingleThreadCOMSTASharedBackgroundBlocking0
000002c4 0 wine_threadpool_waitqueue
000002c8 0 ThreadPoolForegroundWorker
000002cc -2 ThreadPoolBackgroundWorker
000002d0 0 CacheThread_BlockFile
00000288 Zalo.exe
0000028c 0 CrRendererMain
000002e0 0 BrokerEvent
000002e4 0 ThreadPoolServiceThread
000002e8 0 ThreadPoolForegroundWorker
000002ec -2 ThreadPoolBackgroundWorker
000002f0 1 Chrome_ChildIOThread
000002f4 0 wine_threadpool_worker
000002f8 0 wine_threadpool_waitqueue
000002fc 0 ThreadPoolForegroundWorker
00000300 0 GpuMemoryThread
00000304 1 Compositor
00000308 0 ThreadPoolSingleThreadSharedForegroundBlocking0
0000030c 0 CompositorTileWorker1
00000310 0 CompositorTileWorker2
00000314 -2 CompositorTileWorkerBackground
0000031c 0
00000324 0 ThreadPoolForegroundWorker
000003e4 0 ThreadPoolForegroundWorker
000004d8 0
000004dc 0
000004e0 0
000004e4 0
000004e8 0 DedicatedWorker thread
000004ec 0 DedicatedWorker thread
000004f0 0 DedicatedWorker thread
00000290 Zalo.exe
00000294 0 CrRendererMain
00000320 0 BrokerEvent
00000328 0 ThreadPoolServiceThread
0000032c 0 ThreadPoolForegroundWorker
00000330 -2 ThreadPoolBackgroundWorker
00000334 1 Chrome_ChildIOThread
00000338 0 wine_threadpool_worker
0000033c 0 wine_threadpool_waitqueue
00000340 0 ThreadPoolForegroundWorker
00000344 0 GpuMemoryThread
0000034c 1 Compositor
00000358 0 ThreadPoolSingleThreadSharedForegroundBlocking0
00000364 0 CompositorTileWorker1
00000368 0 CompositorTileWorker2
0000036c -2 CompositorTileWorkerBackground
00000370 0
00000374 0 ThreadPoolForegroundWorker
000003e0 0 ThreadPoolForegroundWorker
00000488 0
0000048c 0
00000490 0
00000494 0
00000298 ZaloCap.exe
0000029c 0
00000348 0 wine_threadpool_worker
00000350 0 wine_threadpool_waitqueue
000003b0 0 wine_rpcrt4_server
000003b8 0
000003cc 0
000002d4 Zalo.exe
000002d8 0 CrRendererMain
00000378 0 BrokerEvent
0000037c 0 ThreadPoolServiceThread
00000380 0 ThreadPoolForegroundWorker
00000384 -2 ThreadPoolBackgroundWorker
00000388 1 Chrome_ChildIOThread
0000038c 0 ThreadPoolForegroundWorker
00000390 0 wine_threadpool_worker
00000394 0 wine_threadpool_waitqueue
00000398 0 GpuMemoryThread
0000039c 1 Compositor
000003a0 0 ThreadPoolSingleThreadSharedForegroundBlocking0
000003a4 0 CompositorTileWorker1
000003a8 0 CompositorTileWorker2
000003ac -2 CompositorTileWorkerBackground
0000045c 0
00000460 0 ThreadPoolForegroundWorker
00000498 0 ThreadPoolForegroundWorker
0000035c (D) C:\users\store\AppData\Local\Programs\Zalo\Zalo-24.8.5\Zalo.exe
00000360 0 <== CrRendererMain
00000408 0 BrokerEvent
0000040c 0 ThreadPoolServiceThread
00000410 0 ThreadPoolForegroundWorker
00000414 -2 ThreadPoolBackgroundWorker
00000418 1 Chrome_ChildIOThread
0000041c 0 wine_threadpool_worker
00000420 0 wine_threadpool_waitqueue
00000424 0 ThreadPoolForegroundWorker
00000428 0 GpuMemoryThread
0000042c 0 ThreadPoolForegroundWorker
00000430 1 Compositor
00000434 0 ThreadPoolSingleThreadSharedForegroundBlocking0
00000438 0 CompositorTileWorker1
0000043c 0 CompositorTileWorker2
00000440 -2 CompositorTileWorkerBackground
00000458 0
000004a4 0 ThreadPoolForegroundWorker
000004f4 0
000004f8 0
000004fc 0
00000500 0
00000518 0
0000050c conhost.exe
00000510 0
System information:
Wine build: wine-9.0 (Ubuntu 9.0~repack-4build3)
Platform: x86_64 (guest: i386)
Version: Windows 10
Host system: Linux
Host version: 6.8.0-41-generic
(b) Ubuntu 24.10 (Oracular Oriole)
Note: If you have already read (a) and you do not have 24.10, you do not need to read this. You can use the details above to post an answer.
