10
Is it possible to query (using the command line) what device a particular file or folder is on?
All files are on some sort of storage device (eg. /dev/sda1). These storage devices are mounted at a particular point in the file system hierarchy (eg. /, /home).
I want to find out what device a file is on. For example, if /dev/sda3 is mounted on /home, given the file ~/document.odt, what command can I use to determine that the file is on /dev/sda3?
dv3500ea
  • 37,734
You can use:
df /path/to/filename
It will show the path base mount point.
João Pinto
  • 17,323
