I want to develop an app for ubuntu, that integrates inside the calendar indicator/menu. It should allow to enter info right from it, and have several controls like input boxes, drop downs, spinners and buttons.
Is this possible to integrate/replace the standard date/time indicator?
If not, is it possible to create it as a separate indicator that when clicked opens a popup with all the controls and stuff?
I want it to look as part of the sys tray and not as a separate desktop app.
I'm using Quickly for this.
Thanks for your help!
You can't integrate with the date/time/calendar indicator AFAIK.
You can't add fancy custom menu items either: https://askubuntu.com/a/57276/67335.
So you're left with writing your own indicator which would have a menu and that menu would then launch your config dialog containing the calendar or whatever you needed.
To get you started: https://askubuntu.com/a/501053/67335.
Bernmeister
  • 1,149
